Go Back   Ford Truck Fanatics > Engines > 7.3 Powerstroke
  #1
Old 07-23-2018, 06:25 PM
codeyk codeyk is offline
codeyk is on a distinguished road
Very hard idle help!!!
I have a 94.5 7.3 powerstroke. I took it camping and all was fine. Until I went to leave. I started it. It ran good for 3 seconds then died. Started it again ran good for 3 seconds then just started loping bad. Then when you drive it surges really bad. It feels like you can't eas into the throttle. Rpms just jump to 1500 with the slightest throttle. Can anyone help? Or at least kick my in the right direction. Thanks all
Sent from my SM-G920W8 using Tapatalk
  #2
Old 07-23-2018, 11:31 PM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
of what i could find for the 7.3's in the same description for your symptoms people were saying Crank Position Sensor, Injector Pressure Regulator, Clogged Fuel Filters (not completely but enough to let it start but quickly starve it of fuel), Weak fuel pump, or bad IDM (Injection Drive Module - i had to look that up what it was)... unfortunately no one ever returned in the threads i could find to say what the problem actually was when they solved it...
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #3
Old 07-24-2018, 05:28 AM
dustybumpers's Avatar
Probably like sparky first stated, CPS.
Those fail enough I carry a spare in the glove box
BUT that being said, don't just go throwing parts at it, scan for codes, and find out what's going on
You can get a forscan adapter for your phone that will pull the codes for you, and give you a start
Those scanners are reasonable in price
Money well spent if you are going to service your own truck
Charlie
  #4
Old 07-24-2018, 08:31 AM
Sparky83's Avatar
Quote:
wasnt sure if that year was able to be scanned or not, i would have mentioned it as well if i had knew for sure...
Shawn
-John F. Kennedy
-Christopher Titus
  #5
Old 07-24-2018, 08:48 AM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
It's the original Ford OBD, so it's not a standard OBD2 scanning plug.
You can buy a specific purposed one for Ford for under $40. Or like mentioned above, buy the plug online and get the phone scanning app. I'd check first to see if the computer can give you any hints.
  #6
Old 07-24-2018, 04:29 PM
You pull codes under the hood by the air box, yes it requires an adapter, it is included in the kit
Charlie
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
