Home | Gallery | TOTM | New Posts | My Threads / My Replies | Links | Sponsors | Calendar | Arcade | Calculators | Fliers |
Generations 8-9 1987-1996 F150 + 1987-1997 F250, F350 |
Thread Tools | Display Modes |
#1
96 f250 looses drive
Bert. |
Sponsored Links |
#2
Check codes yet?
Has it ever leaked out the front seal? Is the od light flashing?
Charlie "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool." |
#3
nope no code no leaks no flashin od light. when it works it works like it should. just when it acts dumb drive go's away, turns into neutral like.
Bert. |
#4
*Fluid level when operating propely?
*Fluid level when it's acting up? *Correct hydraulic pressure and correct (or not) when it's acting up too? *Wild card that may/may not apply but, band adjustment?
-Bill -Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you. ![]() 04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded. Useful Ford Vehicle Resources: Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/ Build Information (click on "vehicle") >>> https://www.etis.ford.com/ Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/ Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp |
#5
fluid levels are good don't know about pressure's tho im assuming the trans shop took that reading. personaly I think its a shift soliniod but ive ben told they either work or don't work not intermittent like.
Bert. |
#6
BEFORE you pull the pan Take the heat shield off the side behind the cat converter, and check the wire connection.
It has a heat problem from 95-97, and the connector cracks. If the connections check out, then pull the pan
#7
I told the kid to check that, he hasn't got back to me yet
Bert. |
#8
Was just getting ready to ask, I'm trying to find where I bought the harness repair from, but coming up empty. I'll keep looking, maybe in the garage file cabinet, that repair has been a while ago
Thread Tools | |
Display Modes | |
