Go Back   Ford Truck Fanatics > F-Series > Generation 1
Generation 1 1948-1952 F1 thru F8
  #1
Old 05-12-2018, 03:15 PM
old yella old yella is offline
old yella is on a distinguished road
Hello Everyone
I am new to this so bare with me if you will . I have had many cars and trucks in my life time but never a modified 1949 F1 pick up. I just bought it from an older gentleman who knew nothing about vehicles except buy them and drive them. Anyway this truck has a 305 stroker chevy engine and trans. I just found that out by tracing numbers. Now it has disc brakes in front but the mystery is that it has a 6 lug bolts both front and back so I know this is not a mustang front. I'm thinking 3/4 truck, anyone have a guess ? I'll paste a photo as sonn as I figure out how . Thanks
  #2
Old 05-15-2018, 08:37 AM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Jasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to behold
Are there any numbers cast in to the differential or a metal tag attached somewhere? Maybe post some pics?
- Russell
'77 F100 Flareside
  #3
Old 05-18-2018, 11:54 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond repute
I'm thinking 3/4 truck, anyone have a guess?
No F1/F2/F100/250 had 6 lug wheels, they're probably the same application as the disc brakes.
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
  #4
Old 05-19-2018, 02:51 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Typically Chevy didn't either except in 4wd applications. Initially was thinking maybe they set the body on a Chevy frame. Still quite possible that is the case with a disc conversion on the front unless there were some 6 bolt applications I'm not remembering.
My trucks:
  #5
Old 05-20-2018, 01:44 PM
I took it to get new tires 15" and they said a tie rod was bad but could not do anything with out knowing what front end it is. The caliber has only one marking 2 1/8 2113-1. And that doesn't help. Since it has a 1985 chevy 305 with power steering and disc brakes I was thinking maybe an 85-86 chevy truck front end as well. I believe the ck had 6 lugs. I guess I need to know would an F1 fit on that truck frame. I am going to bring it to a front end specialist as soon as I can and see if they can figure this out. I would love to post pics but not sure how. Soon I hope.
  #6
Old 05-20-2018, 08:31 PM
Okay I just got a piece of the puzzle, I found rims to fit exactly from a GM colorado/canyon/Izuzu 2004-2008 6 lug offset 15x6.5j . also while cleaning the engine compartment I noticed on the steering box a metal tag completely covered in dirt that read 5826250 and the name toyo. So I am assuming this is part of the GM / Izuzu partnership that was going on until 2016. Hopefully I will get pics on soon, this is a good looking truck just a mystery.
  #7
Old 05-22-2018, 03:43 PM
I posted photos in the gallery of my 49. This truck supposedly came out of Tennesse, anyone ever seen it before ?
  #8
Old 05-22-2018, 04:02 PM
fatherdoug's Avatar
Wow! That's beautiful. I hope you don't mind, but I posted your pictures from your gallery, so everybody can see them.
'78 F-150 Lariat
Quote:
Quote:
  #9
Old 05-22-2018, 04:16 PM
Thanks no I don't mind. now to put a new gasket in for the cowl and the new wiper motor I ordered, Ac and it's good to go ! I hope to drive it everyday and enjoy it
  #10
Old 05-22-2018, 09:45 PM
Fellro's Avatar
Admin
The Isuzu connection sounds more likely to have the 6 bolt rims. A possible quick way to check is look at the frame. Open C-channel was common on domestics, while the imports used a more rectangular tubular style. Get into the later 90's and 2000's, that became less true.
My trucks:
