  #1
Old 04-29-2018, 11:58 AM
mycapricess mycapricess is offline
mycapricess is on a distinguished road
water coming in
I have water coming in the cab on the seam right by the steering colum any idea where it might be coming from? I do not have the seal wear firewall meets the hood. Will add pics later. thank you
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #2
Old 05-03-2018, 08:00 PM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Jasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to behold
There should be seem sealer between the upper and lower sections of the firewall. If that was ever cleaned out it might leak if water splashes up on the firewall.
Might also be that water is coming in between the steering column plate and firewall if that gasket has deteriorated.
- Russell
'77 F100 Flareside
  #3
Old 05-07-2018, 05:54 PM
406f150 406f150 is offline
406f150 is on a distinguished road
I get water coming in mine through the foot vent on the passenger side if it rains very hard. I need to take it all apart and check out why. I suspect enough stuff has fallen in the top opening between the hood and windshield to block any kind of drain hole it may have before coming in the cab. When I first got the truck there was all kinds of pine needles in there, and the first high-speed trip down the highway with the floor vents open it blew all kinds of needles, leaves, and dirt out of them.
