  #1
Old 12-23-2017, 09:44 AM
fatherdoug's Avatar
Aluminum heater cores?
I have been needing to change my old heater core in the '78. I just don't get the heat that I used to into the cab. I purchased a new aluminum heater core about 2 years ago, and have been on the fence about replacing the brass core with aluminum(Enter horror stories here.)
I am not having much luck finding a new brass core for the '78 with factory air.
So........My question is, if a person is anal about keeping the antifreeze in very good shape such as flush, replace on a regular basis, could a person prolong the life of the aluminum heater core?
'78 F-150 Lariat
Quote:
Quote:
  #2
Old 12-23-2017, 10:10 AM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
I would think it would be fine. May even put out a little more heat than the brass one
-Frank
Quote:
What's your view on sheep?
  #3
Old 12-23-2017, 10:33 AM
fatherdoug's Avatar
That's what I am thinking also, Frank. The key is to take VERY good care of the coolant system. Thank you.
'78 F-150 Lariat
  #4
Old 12-23-2017, 10:48 AM
dustybumpers's Avatar
owned by Fords
Most radiator cores are aluminum now as well
I'd use it
Keep in mind, they make test strips to check your coolant, then you know for sure when it's time to flush and change
Charlie
  #5
Old 12-23-2017, 11:15 AM
fatherdoug's Avatar
Thank you, Charlie. I have access to a full scale metallurgical lab.
'78 F-150 Lariat
  #6
Old 12-23-2017, 02:56 PM
TheBandit's Avatar
TheBandit TheBandit is offline
TheBandit has a spectacular aura aboutTheBandit has a spectacular aura about
Also make sure to use distilled water to help prolong the life of the aluminum.
  #7
Old 12-23-2017, 03:06 PM
fatherdoug's Avatar
Very true!
'78 F-150 Lariat
  #8
Old 12-23-2017, 04:25 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
I've used aluminium cores and have never had a problem with them.
Click for weather forecast
________________
Randy
  #9
Old 12-23-2017, 04:36 PM
fatherdoug's Avatar
Good to know! Thank you.
'78 F-150 Lariat
  #10
Old 12-23-2017, 05:37 PM
cbaker65's Avatar
cbaker65 cbaker65 is offline
cbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond repute
Aluminum is tricky to maintain ,it is capable of lasting 500 years barried
into the ground if conditions are right!
The right combo of moister & oxygen can cause atralisis on aluminum ,
there for ,aluminum does not like to be smothered with dirt or paint!
Aluminum likes open air or if it has some kind o protectant fluid on it!...
CB
Im not a bum,Im on vacation!....
