  #1
Old 12-02-2017, 11:11 AM
cflcoltfan cflcoltfan is offline
cflcoltfan is on a distinguished road
steering box question.
I have a 1979 f-150 4x4 with a 302 cid V8 engine. I bought this truck from another gentleman who had disassembled the truck for a future off frame restoration. The frame was a rolling chassis without an engine and transmission.
the question I have, the power steering hose connection ports on this steering box are pointed down toward the ground. This makes the running of the hoses somewhat awkward. Question is, can this be correct, would this inhibit getting the air out of system? Can this part of the steering box be installed wrong after being rebuilt? In other words, can the 4 bolts be removed and simply rotate the input shaft housing 90 degrees and reattach hoses? The reason for the question is I have never seen in all the photos on line, a box with lines going anywhere but upward. Thanks for your help in advance.
  #2
Old 12-02-2017, 04:17 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant future
Quote:
Engine has been swapped. No 302's with 4WD until 1980.
What engine did this F150 come with originally? Is this a Regular or Super Cab?
Warranty Plate riveted to the left door face below the latch.
Post the Warranty Number (VIN).
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
  #3
Old 12-03-2017, 08:36 AM
Yes. I installed the 302 I had built for another truck. The existing engine was torn up. It was a 351M with a 4spMT. I went out and purchased a small block bell housing to mate the two. The vin # F14HUDJ1923 It is a regular cab.
  #4
Old 12-03-2017, 11:47 AM
Fellro's Avatar
Fellro Fellro is offline
Admin
Looking at the parts photos from parts sites, they do point downward like that.I can try to go get a look at the 78 F150 4x4 I have and get some pics maybe.
My trucks:
  #5
Old 12-03-2017, 12:54 PM
dustybumpers's Avatar
owned by Fords
That is the correct box
Getting the air out of the system is done by turning the wheels back and forth, while the pump is being driven. It bleeds itself.
Charlie
  #6
Old 12-03-2017, 02:55 PM
Thanks guys, you have been very helpful. Have to get back to the body work.
  #7
Old 12-03-2017, 02:56 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
VIN: F14HUDJ1923
F14 = F150 Regular Cab 4WD Pickup.
H = 351M
U = Louisville KY Assembly Plant.
DJ1923 = 1979.
2017 Fusion SE
