  #1
Old 08-19-2017, 12:47 PM
skyrader skyrader is offline
skyrader is on a distinguished road
turn signal lights up tail light
weird problem is the rear turn signal crosses from turn/brake filament of bulb to the tail light filament. it's doing this on the left or right. when I turn on turn signal it crosses back n forth to the tail light. Anyone had or heard of this issue? where do I start to look? Do I have a short some where?
  #2
Old 08-19-2017, 01:17 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Bad ground would be the first thing to check.
My trucks:
  #3
Old 08-19-2017, 01:58 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
or a bad bulb
ase master tech--fmc senior master tech (retired)
  #4
Old 08-23-2017, 08:08 AM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Jasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to behold
I've had all kinds of issues like that with bad grounds. Also had bad sockets cause issues like that.
I would start by checking grounds. I ended up adding numerous ground straps which cleared up some weirdness I was having.
Also check to be sure the wiring harness isn't pinched or damaged somewhere causing shorts.
- Russell
'77 F100 Flareside
  #5
Old 01-08-2019, 12:50 AM
rjphillips's Avatar
rjphillips rjphillips is offline
mudman
rjphillips will become famous soon enough
My 77 F250 was just doing the same and was my signal light switch, so bought another, pulled the wheel changed it and works great, hope yours is an easier fix.
Mudman.
Early 77 F250 Highboy
400 C6
33" SSR swamper radials on MT classic III
  #6
Old 01-08-2019, 08:05 AM
dustybumpers's Avatar
Check for an old trailer wire hook up that is disintegrating, and shorting out
Charlie
