Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > Certified Ford Tech Help Forum
Certified Ford Tech Help Forum Got a mechanical problem or question about your Ford Truck? Post it here for answers.
  #1
Old 07-20-2015, 10:19 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
2012 Edge 2.0 Ecoboost low boost code
So, just before the vehicle went out of warranty, the turbo died. Now, about the same number of miles since the new turbo was put on, it is intermittently giving a check engine for low boost. It also seems to come up in high humidity situations. Is the turbo on the way out again, or is it more in the control functions?
My trucks:
  #2
Old 07-21-2015, 08:34 AM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
Need to know the code number. There's several for turbo related problems, including turbo control components.
ase master tech--fmc senior master tech (retired)
  #3
Old 07-21-2015, 01:13 PM
Fellro's Avatar
Admin
Ok, when it resets I will get it aqain, forgot to write it down.
My trucks:
  #4
Old 08-07-2015, 09:50 PM
Fellro's Avatar
Admin
So it reset again. p0299 low boost detected.
My trucks:
  #5
Old 08-08-2015, 03:31 PM
Super Moderator
Super Moderator
The DTC points toward control components...Turbocharger wastegate regulating valve solenoid, turbocharger wastegate regulating solenoid valve stuck, wastegate stuck open, wastegate control hose open or plugged, air leak between turbocharger and throttle.
  #6
Old 08-08-2015, 05:31 PM
Fellro's Avatar
Admin
It is intermittent, so any ideas as to a direction to look at in all of that? Hasn't seemed to cause much of a driveability issue just yet. The light was actually back off by the time I got there to retrieve the code.
My trucks:
  #7
Old 05-31-2016, 08:36 PM
Fellro's Avatar
Admin
So we took it in to the local Ford dealer to check it out as these issues still haven't resolved and figured it was more than I know. Their diagnosis found the P0299 and P018D codes. Monitored the pids, found the fuel pressure sensor was not reading correct. Found low side pressure sensor was unplugged. Cleaned out the plug and tested ok.
So now, again the P0299 code for low boost is back again. They said the turbo was fine, estimate the cost of repair to be $500. I am not certain where the low pressure sensor is, or what it would take to replace it. Mom is now disabled and dealing with cancer so if it is something I can handle it would be appreciated if you could help me out with this. Thanks!
My trucks:
