Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.1
Superduty Gen.1 1999-2007 F250, F350, F450, F550
  #1
Old 07-04-2015, 08:13 PM
Blacktruckdave's Avatar
Blacktruckdave Blacktruckdave is offline
Blacktruckdave is on a distinguished road
2007 Superduty Transmission Fluid
With 140k hiway miles on my truck and a good bit of towing a 14' trailer should I be changing my transmission fluid anytime soon and what is the best product to put in? Thank you in advance
  #2
Old 07-04-2015, 09:19 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
Mercon LV
ase master tech--fmc senior master tech (retired)
  #3
Old 08-07-2015, 12:41 PM
thank you blacksnapon..I finally got around to emptying the pan and changing the remote filter. I only got a little over 2 gallons out of it. I've read different procedures for flushing the rest but they seem to vary. Any tricks or links to what you would recommend?
  #4
Old 08-07-2015, 01:25 PM
Super Moderator
Super Moderator
Without going through all the nonsense of heating the internal thermostat to flush it completely, just dropping the pan periodically will do a pretty fair job.
  #5
Old 08-07-2015, 05:30 PM
i read a post saying that if you drain the pan and then pour in 2 quarts thru the dipstick hole and run the truck for 10 seconds and turn it off, drain the pan again and repeat this for 4 quarts it will flush for you. Does that make sense to you?
  #6
Old 08-07-2015, 08:34 PM
Super Moderator
Super Moderator
Quote:
Nah, you don't want to run it dry.
  #7
Old 08-07-2015, 10:40 PM
good to know. Thank you
