Go Back   Ford Truck Fanatics > F-Series > Generation 7
Generation 7 1980-1986 F150, F250, F350
  #1
Old 01-06-2015, 09:20 PM
crazycanuck's Avatar
crazycanuck crazycanuck is offline
crazycanuck has a spectacular aura aboutcrazycanuck has a spectacular aura about
1986 supercab
Just picked this truck up in Dec. Had a blown 9inch. Gave the guy 200 bucks , he said I'd need a trailer.... I walked around it, locked in the hubs in, pulled her into 4x4 and drove her away... And around town for 2 weeks like that. So here it is from start to now...
  #2
Old 01-06-2015, 09:33 PM
Details are 302 efi. NP 435 , a/c works well. 275xxx kms on her. What I've done are 6 inch rough country lift, new to truck rear end from my now parts truck, grill swap with parts truck New brakes, brake hoses, every u- joint , clean and repack front wheel bearings, 2 inch leveling spacers , new shocks with lift kit, new steering wheel , plugs, wires, cap and rotor, headers, custom exhaust, winch, pushbar, 40 inch lightbar on front. Also installed cutout fender flares.Here are a few more pics
  #3
Old 01-06-2015, 10:03 PM
Big Jim F150's Avatar
Big Jim F150 Big Jim F150 is offline
73-79 Ford Trucks Rock
Big Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the rough
Not bad, for that style truck, but I prefer Dents myself
Big Jim F150
1978 Ford F-150 Ranger Lariat
  #4
Old 01-06-2015, 10:11 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Is the back of the truck sitting low, or is it just the way it is sitting on the street?
BTW, nice work, rig looks good.
My trucks:
  #5
Old 01-06-2015, 10:12 PM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
What a change! looks fantastic I just sold my 2 wheel drive '83 f250 Supercab. Been selling parts that I had collected over the years, not much left but here's what I still have.
tachometer but not the printed circuit board
rubber floor dimmer switch cap (hard to find)
spare gauges
gas pedal spring (which keeps the pedal flat on the arm)
digital clock
under hood work lamp
some other little things, have to look
let me know in a PM if you could use any of this, I'll give it to you for free
Roy
yeeooow!
  #6
Old 01-06-2015, 11:12 PM
Thanks Big Jim, I also prefer the other body style better too. The one in my avatar pic is one I built previously.
Fellro, yep she sits slightly lower in the rear, planned it that way. I like to be different haha
Amkatt1, always good to know where to source more parts, espically rare and hard to find items. I'll definately keep you in mind . Thanks
  #7
Old 01-14-2015, 04:32 PM
I just dropped some coin on some chromalloy CV front axle shafts for the supercab. Can't wait. Also upgrading to 30 spline warn premium lockout hubs. Hoping for smooth power delivery to the front wheels while steering. Also the chromalloy shafts are significantly stronger than stock. That's good because they have to turn 39' superswampers.
  #8
Old 01-14-2015, 08:29 PM
Fellro's Avatar
Admin
I am a little confused... are you expecting the lockout hubs to make a difference when turning? Unless I am missing something, they won't make any difference there. They are simply to engage the axle so it will turn the wheels, but will not make a difference on the ability to turn while engaged.
My trucks:
  #9
Old 01-14-2015, 09:36 PM
Fellro, replacing the 3 u-joints axleshafts with chromalloy axle shafts with CV joints in place of the u-joints. Also upgrading from the 19 spline putter stubs to 30 spline outter spline stubs. I'll need the warn premium lockouts to work with this setup
  #10
Old 01-14-2015, 09:43 PM
Fellro's Avatar
Admin
I would expect the same issues on turns though even with all that. The lack of give between the front tires gives the catchy feeling when turning in 4wd, especially worse with lockers. CV joints are just a ball bearing u-joint in essence. I get that you are adding strength, it is the
that I don't understand.
My trucks:
