Go Back   Ford Truck Fanatics > F-Series > Generation 1
Generation 1 1948-1952 F1 thru F8
  #1
Old 07-31-2013, 09:02 PM
Jerodsford Jerodsford is offline
Jerodsford is on a distinguished road
302 motor mount on 1951 frame
got 1983 mustang 302. so what am I doing with motor mounts. pICS WOULD BE HUDE AT THIS POINT!!!!
  #2
Old 08-01-2013, 11:23 AM
mtflat mtflat is offline
Flatheads Forever
mtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond repute
Sorry for the delay...my internet is down at home so I'm not on here much at present.
There are lots of shops online that make engine mounts/adapters/crossmembers for this swap.
The simplest involve an adjustable tube that goes from frame rail to rail and has the mounts welded in place for a 302 in an F1.
Online search should show up several.
...Tim
  #3
Old 08-01-2013, 09:04 PM
havi's Avatar
havi havi is offline
third member
havi is a jewel in the roughhavi is a jewel in the roughhavi is a jewel in the roughhavi is a jewel in the rough
Speedway Motors is one link to search
I'm just an old truck guy trapped in a hot rodder's world
1948 F1 1949 F6
1999 Ranger ext cab 4x4 1998 F150 XL ext cab 4x4
1978 F150 4x4 1979 Ford Bronco
1946 Tonner, looking for 1941 body panels
  #4
Old 08-01-2013, 10:14 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has a spectacular aura about52 Merc has a spectacular aura about
Quote:
It would be good to know what front suspension you're running? Stock? M2? Something else??? Frame mounts are pretty basic to build yourself to utilize whichever insulator you're going to use.
Wayne
52 Mercury M-1
  #5
Old 08-04-2013, 08:50 AM
well honestly hadn't even thought about the suspension left. As I am sure you can tell half the fun for me and my kids are researching all the info, looking at options and deciding which way to go.
That being said I was hoping to soften up the suspension for a more comfortable ride but haven't even started to look at options.
  #6
Old 08-08-2013, 08:14 AM
Mt original goal was to use the front motor mounts on the frame. Is there any application for a 302 that uses the original front motor mounts on the frame?
The previous engine had a bracket that connect to the front of the block and then sat on top of the frame motor mounts.
Thanks
  #7
Old 08-08-2013, 11:47 AM
Flatheads Forever
Anything is possible. A 302 is roughly the same size as the original flathead V8, but the flathead sat on feet cast into the front-mounted waterpumps. The std 302 uses center-block attachments......
You could custom make mounts that would reach the diagonal crossmember as long as it cleared your accessories. I don't know of any commercially available.
...Tim
  #8
Old 08-08-2013, 04:54 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
If you want to front mount, you can use a plate like this one to hook up to the sides.
http://www.jegs.com/i/Competition-En...00#moreDetails
My trucks:
  #9
Old 08-09-2014, 11:34 AM
TractormanBill TractormanBill is offline
TractormanBill
TractormanBill is on a distinguished road
Here is what I used but I don't know how they will work in the long run over time.
Bought them from one of the racing catalogues and they are welded in.
TractormanBill
  #10
Old 03-04-2015, 03:48 PM
TractormanBill
302 in F-1
Better watch out for the front or rear sump pan if you go with a IFS.
I had to change to a rear sump & pump oil pan on my 302 because I would have had to set the engine way high to change the oil on a front sump.
TractormanBill
