so i decided to stay on the efi system for my truck, but have some questions id like to clear up:
1. an upgrade for it should be an injector swap out of an 302, how efficient will this be
2. i'm burning 98 octane fuel, should i retard timing to 12 (or more)
3. coupled on question 2, i also run propane/butane mixture on it? same question for timing.
4. i heard throttle body of a 302 should fit but would it be a gain or even a no fitter.
5. long skinny intakes should give some low end torque, since my air filter is now at prox 4inch of my throttle body would it help to make it +-double the length?
6. air filter is now fitted on a impco 300A carburator, (this is for the PB setup) does k&n air filters really work.
7. exhaust is now an open pipe behind the cat, i would remove the cat make a true dual exhaust the size of the pipes coming from the headers. then have some good mufflers on it. which brand and type would be good?
8. since egr system is no longer functional i'm removing it, is the cilinder shaped canister on the pass side fender part of this system? if not what is i for?
9. are there any chrome parts for an 4.9 efi?
10. should i install a tc which has lower stall speed?
11. would a camshaft which has +-10° difference make change in mid power band?
12. i also read somewhere that the 1st and 2nd gear of an AOD can be put into a C6 anyone done this? is it an easy swap?
13. have a C6 that need a rebuild and saw somewhere (sorry can't be precise on anything) they changed bushings by bearings to gain a bit of hptorque extra to the rear axle.
all these questions come because i like the six-inline however i sometimes need it to climb hills and instead of going up the speedo goes down. and i always have to manually shift between 2nd and D to get uphill: 2nd makes too high rpm but after a while in D it looses too much. also don't want to change rear diff ratio because it already does 3000rpm at 65mph and even if possible would put in a diff making this 2700rpm so need more torque on the band between 1400 and 2700 rpm. (doesn't have to drive faster then 85)
i know there are a bunch of question but any help would be great
