  #1
Old 02-15-2012, 09:27 AM
MikeStoke's Avatar
MikeStoke MikeStoke is offline
Army Firefighter
MikeStoke is on a distinguished road
Starting Problems
I have a 1995 f-150 That sometimes when i start it the dash lights start blinking on and off and i hear a clicking sound. Now sometimes I try to start it and It will click, click like the battery is dead, then I can try it again and it fires right up. The battery is new and the alt. has been checked and is good. Could it be a computer problem or maybe a solenoid? I am not getting a light on the dash so not sure if its throwing a code. Should I take it in and see if a code can be read?
2004 F-350 LARIAT SDD DRW 6.0
STOCK
  #2
Old 02-15-2012, 09:57 AM
Alvin in AZ Alvin in AZ is offline
Alvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud of
a code can be read?
Get an analog volt/ohmmeter and/or a friend that's got one then let the
meter tell you (guys) -exactly- where the trouble/s is/are!
Any other way is a crap-way to do it.
No kidding on that. :) Funny thing is, it's easy as anything to use a meter,
but, you ain't gonna follow my advice! LOL :)
You'll swap parts until you "fix" it (or just clear the trouble up on yourself)
...so it can return later. Seen it a jillion times.
Please prove me wrong about assuming you're like almost everyone else. :)
I'll be happy as a frog for both of us. LOL :)
Alvin in AZ
  #3
Old 02-15-2012, 11:51 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Alvin is right! A meter is your best friend with this type of issue.
Sounds like a wiring or Ground issue. Check all your grounds, and connectors one may be corroded a meter can tell you this by reading the voltage drop in the circuit.
Click for weather forecast
________________
Randy
  #4
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
loose battery cables/connections, either at the battery or the starter.
ase master tech--fmc senior master tech (retired)
  #5
Old 02-21-2012, 01:10 AM
optikalillushun optikalillushun is offline
Coal Cracker
optikalillushun is on a distinguished road
I also had issues where the starter relay/solenid on the inner fender isnt grounded properly. make sure the attatching bolts are tight. if u are still having issues u can try to jump the solenoid but that is kind of dangerous.
Start with cleaning the battery cable connections, check for loose grounds (and the starter relay/solenoid on the fender) and work from there. after that check for voltage like Alvin said.
  #6
Old 02-21-2012, 05:11 PM
73F100Shortbed's Avatar
73F100Shortbed 73F100Shortbed is offline
73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute
Sounds like a ground problem to me as well. Check your cables and connections like suggested.
Sean
1973 Ford F100: 302, 3-speed, dual exhaust with glasspacks
New Jersey Chapter Leader:Click here to Join
Click for Woodbridge, New Jersey Forecast
  #7
Old 02-26-2012, 10:40 AM
RollinThunder RollinThunder is offline
RollinThunder is on a distinguished road
my truck did this a few weeks ago and at first i thought the starter or the battery was going out but after a closer look at the ignition wire that runs to the starter it was frayed and i talk to a few local mechanics and it turns out that it was a consant problem on fords for that wire to wear out so for 7 bucks i replaced and i havent had a problem since then
  #8
Old 02-26-2012, 06:02 PM
john palmer john palmer is offline
john palmer will become famous soon enough
Yep, what Blacksnapon said. I had a similar issue with my 94 f-350, cleaned the terminals at the batteries, ground, and starter and the problem was solved. my truck is a psd 7.3, and the glow plugs weren't working well and it was corroded conections to blame. Cleaned em up, and now she fire at 10 degres without pluging in. (hasn't been any colder here in Mi, this year!)
