Go Back   Ford Truck Fanatics > Special Interest > Off-Road
  #1
Old 11-15-2011, 07:13 PM
primetime's Avatar
primetime primetime is offline
sawmill slave
primetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond repute
Hillbilly Hot Rod
Thought I`d put up some pics of my buggy project.
It`s a K-5 Blazer frame with a cage from a 97 Windpusher dirt modified. It was built by a Chevy guy. I helped skin it and won a trophy at the local bogs. Then he sold it, got it back with no engine, and gave it to me.
I`ve already hung the Dana 60 front, that`s a 10.25 dually rearend almost mounted, it`s going to be powered by a 351w with a T-19 and a 13-56.
By the way, that`s a 35x14 Ground Hawg next to the 42x25x20 that will be going on it.
  #2
Old 03-24-2012, 10:10 PM
primetime's Avatar
sawmill slave
Thought I should get back on this. Hey it`s been a year.
I`m going to use the 302 that was in my 94 F-150 for the time being because I already have a clutch and flywheel, and I haven`t got the 351 finished yet.
The stuff I took off it.
I`m real sure this engine has 250,000 miles on it. I say real sure because I bought it with 140,000 and it seemed pretty oe.
Engine porn!
________________________________________
Justin
With a little luck and a greenback dollar you gonna see me shine.
  #3
Old 03-24-2012, 10:13 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Looks like a cool project.
Click for weather forecast
________________
Randy
  #4
Old 03-24-2012, 10:17 PM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
looks street legal the way it is
cool toy!
Roy
yeeooow!
  #5
Old 03-24-2012, 10:45 PM
primetime's Avatar
sawmill slave
Quote:
cool toy!
Work is 5 miles away straight up the secondary road I live on. Sooo, there is the possibility of me slapping some 35`s on it and driving it every now and then just cause I can but not very often. It`s main mission is to bomb around the neighborhood, and go to the local mud bogs.
Thanks for the comments. They help with my motivation.
Justin
  #6
Old 03-29-2012, 09:10 PM
primetime's Avatar
sawmill slave
Ordered this the other day. Doesn`t look to bad. For $50 I`m willing to try it.
Also got him pushed into the garage and started working on getting the engine and trans mounts figured out.
Justin
  #7
Old 03-29-2012, 09:38 PM
flareside_thunder flareside_thunder is offline
flareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond repute
50 bucks for the whole dizzy, cap and coil? Daaamn, you stole that!
  #8
Old 03-30-2012, 07:56 PM
primetime's Avatar
sawmill slave
Quote:
Yep, the whole thing. Shipped to my door for $48.00. If anybody is interested you can get them at www.skipwhiteperformance.com. It`s a brand new unit that is pretty nice looking. Hopefully I should know how it works in a month or so.
Justin
  #9
Old 03-30-2012, 08:08 PM
Ridgerunner's Avatar
Ridgerunner Ridgerunner is offline
Ridgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond repute
Great project... Send me the Cougar.
Please Vote It's a great way to bring more members.
1998 Ford Expedition 4X4
2000 Mustang Drop Top
  #10
Old 04-01-2012, 02:19 PM
primetime's Avatar
sawmill slave
Did you mean this Cougar?
I got it a couple of years ago. It was a running and driving car, if you consider a worn out idler arm, no front shock bushings, and wandering all over the road driveable.
Then the po melted the shifter cable, dropped an exhaust pipe, and went to jail.
I towed it home and now I`m trying to get it to run but it won`t crank. I`ve changed the ignition switch because it wasn`t being all it could be, put a new starter switch and cable on it, and swapped ground cables.
When you try to crank it with the key the voltage regulator clicks and nothing happens. It won`t roll if you jump the s terminal, but it will if you jump the two large ones. IDK. And my test light is AWOL.
Justin
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
