Go Back   Ford Truck Fanatics > Engines > 4.6L/5.4L/V10 Modulars
  #1
Old 01-31-2011, 06:58 PM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
5.4L Intake whistle when cold
Hey all.
In the 05, I get a whistle from the engine compartment at certain speed/rpm combinations. It only happens when the ambient temperature is cold.
Are there any particular parts or gaskets that give out with a minor leak? The thing just whistles... No idea where to start looking.
  #2
Old 01-31-2011, 07:09 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
If its running ok, dont worry about it. Engine coolant is a factor for IAC operation.
ase master tech--fmc senior master tech (retired)
  #3
Old 01-31-2011, 07:13 PM
I didn't know what an IAC was until I googled it. Idle Air Control?
It does it even when the engine is warm, it only whistles when the ambient air is cold. It's running just fine though.
  #4
Old 01-31-2011, 07:18 PM
Super Moderator
Super Moderator
Intake leaks can generate a whistle, but there would probably be driveability issues. You might spray carb cleaner around to locate any air leaks. Its probably internal though.
  #5
Old 01-31-2011, 07:25 PM
Thanks Vince. Maybe I'll pop off the Idle Air Control and see if it's got any gunk in it I can clean out.
  #6
Old 01-31-2011, 07:44 PM
Super Moderator
Super Moderator
Try that and a carb cleaner soaked rag on the butterfly and mating surfaces inside the throttle body. There isn't any tsbs related to the symptom.
  #7
Old 01-31-2011, 07:55 PM
Quote:
Cool. Will do. Thanks for the help Vince. I feel better about there not being a vacuum leak.
