I got this truck last year, hood was no good so put a 85 hood on, leaves some gaps and engine gets wet.
It rained (monsoon) for 4 days, and when i went to start the truck, it almost immediately tried to start then absolutely nothing.
depressed he fuel rail "stem" and got nothing, same while starting.
Here no pump.
pulled leads and volt-meter says no voltage. all fuses are good.
was told to check relay's under hood by firewall on drivers side, i don't find any, and i have seen them on other trucks.
right not this is my only vehicle (rebuilding toyota, keep the F350 out of the mud if possible), any suggestions?
BTW, recently when 4 wheeling over bumpy roads it quits like someone turned the fuel pump off. after a little effort it will start. The wiring really looks ok, e.g. wrapped, not chafting against the frame, etc.
appreciate any help,
dave
Here no pump.
dave
