  #1
Old 03-16-2010, 11:39 PM
78_f150 78_f150 is offline
78_f150 is on a distinguished road
Brake light and turn signal problems.
Hello all. Im new to the forums here. This is my first Ford truck and so far i love the truck! its an awesome machine. Anyways i have a 1978 F150 custom 2WD standard cab truck.
when i bought the truck i picked it up for 600$ with a solid running 351m and minimal rust. well i drove it the night i got it and no dash lights? hmmm. also no brake lights? hmmm and turn signals were only in the front.
so heres my problem now. got the front blinkers working, and got one brake light and taillight working. But NOW heres the funky part. when i turn my headlights on the front turn signals light up, and the one rear taillight but when i turn the signals on NOTHING. flasher clicks and indicators in the dash flash. but no signals. BUT turn lights off the turn signals work good???
also why no dash lights? and when i turn the lights on the passenger side turn signal indicator in the dash stays lit??
I have cut and soldered on new bulb sockets on the taillights but only the drivers side works? and how come when my lights are on, brake lights and signals dont work?
NO blown fuses, tried replacing the flasher and that didnt help. bad headlight switch? any ideas?
  #2
Old 03-16-2010, 11:55 PM
TexasRho83's Avatar
TexasRho83 TexasRho83 is offline
Texas Chapter member
TexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant futureTexasRho83 has a brilliant future
You need to start tracing wires bro. It's the caveat when purchasing a 'bargain' truck
One thing to make sure of is the bulbs you use on your turn signals are dual filament. One shines brighter than the other - that's the turn signal filament. The one that's dimmer is the parking light filament. I've actually put the bulbs in wrong to where the filament roles were switched (blinker filament was dim and parking light overpowered the blinker).
The dimmer filament stays on when your headlights are on, but in order to see the blinker filament it must overpower the dimmer one - hence why it's brighter when the turn signal is activated.
All about John Wayne, Johnny Cash, and John Deere...way out here - Josh Thompson
- Charles
  #3
Old 03-17-2010, 12:03 AM
thanks.
maybe i will try flipping the bulbs around. because the front signals are BRIGHT with the headlights on. so maybe i got them in backasswards? they are new bulbs and they are dual filament bulbs.
a new headlight switch is 14.99$ at the parts store, and i found a piece called an Instrument cluster voltage regulator? they are 44$ but i might try to junkyard one and see if those parts help.
I am really good with wiring, i come from working on nissan 240sx and toyota corollas and imports, and efi wiring and new car wiring is crazy compared to this old truck haha. Im for sure enjoying the truck way more then any cars ive owned! cant wait to do more work, just trying to figure out the lighting first of all.
  #4
Old 03-17-2010, 12:08 AM
TexasRho83's Avatar
Man I've had 5 or 6 of these mid 70s model Ford trucks and you can't beat em for simplicity and durability. Not to mention they just look friggin awesome. You will surely enjoy the experience...and quite possibly become an addict like most of us lol.
That regulator won't dictate what turn signal indicator you see lit up on your dash...it's for the gauges. Check out this thread here...may help you out.
- Charles
  #5
Old 03-17-2010, 04:27 AM
TexasNomad's Avatar
TexasNomad TexasNomad is offline
FTFS Designated DRINKER!
TexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond reputeTexasNomad has a reputation beyond repute
Didn't read it all or the replies so if, this has be covered sorry..
First check fluid and pressure .. if not then try the things that have plagued my truck at first and my friends trucks.
Is the socket its self, depending on type of bulbsocket is the connections that touch the bulbs are rusty or just not making good contacts and there is a ground in there to, all most all the issues with my lights have been bad connections, on every thing! Over time scum and rust works its way in to plugs and connections on every thing, try that first on every thing you think is bad before you go chasing wires.
oOoOoo is that a short bed!!?
06 F250 4x4 6.4
94 Bronco 5.0
02 Ranger Edge 4x4 4.0
Tex the AK-toting Liyote
  #6
Old 03-17-2010, 09:19 AM
LEB Ben's Avatar
LEB Ben LEB Ben is offline
LEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond repute
Mike is right on the money, more than likely your issue(s) are crudded up contacts. So I'd go through and clean up every socket (personally, I just like to replace them at only $7 a piece), then clean out every plug (12-18" behind the headlights and the rear harness), then I'd check ground straps. I'd say about 90% of lighting issues in these trucks are caused by those things.
As for your dash lights, not trying to be a smartass, but did you twist your headlight switch all the way to the right? If that doesn't do the trick, time to replace some dash bulbs.
'77 250 400 Boggers (show)__'96 350 CC 460 SSR's (work)__'79 Bronco 400 35's (play)
Quote:
Inspired by Ian
We live in a society that keeps finding answers to problems people never knew they had.
I bow my head to Jesus, stand for my family, love only one woman, and am always proud of what I have.
Standing by my gun and Bible since 1986.
Ben
  #7
Old 03-18-2010, 12:43 AM
did some work today....
heres what i found:
fixed the drivers side lighting. brake light works, taillight works, turn signals work with both lights on and off. I had the bulbs in wrong or something but its working now.
Passenger side? Blinker work lights off, but lights on the dash indicator stays ON and the blinkers dont work? also no brake or taillight? BUT i have 12v at the socket and even in the socket. even spliced on NEW sockets!?! ground is good, ohm'd that out and checked the wires and the ground is good.
So i get 12v through the socket and the blinkers work lights off, but lights on no blinker no taillight no brake light?
My problem is a short somewhere causing the dash indicator light to stay on, which in turn i think is causing my problems. but where the hell is this short? its obvisoully still giving me power to the sockets and ground? its super wierd??
AND NO DASH lights still!
  #8
Old 03-18-2010, 07:02 AM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
We will Rise Again
bucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond reputebucks77ford has a reputation beyond repute
Lighting can be an electrical nightmare in these trucks. Ben and Mike have already hit on great points. I'd also have to say that corrosion and grounding is almost always the problem. Even though you may think you have good grounds, sometimes you actually don't. One bad ground can lead to some really weird things and drive you nuts. I would say start with your grounds and sockets again (all of them, even the headlights). Make sure everything is clean and you have good grounds. Even if a ground wire looks good, disconnect it and clean it up. I've even just ran temporary ground wires straight from the battery or Chassis to eliminate using the body as the grounding source. You just want to eliminate the ground as a problem. Unfortunately, that can be time consuming and frustrating. Once you have done that, then I'd look into things like the the blinker switch itself, brake light switch, signal flasher on the fuse box and light switch.
1977 F250 4x4 Highboy
521 Stroker D44/60 C6
  #9
Old 03-18-2010, 09:34 AM
TexasRho83's Avatar
Honestly, with that much trouble, I'd re-wire all of that mess...
- Charles
  #10
Old 03-18-2010, 09:45 AM
We will Rise Again
Quote:
I also was thinking along that lines. At least replace all sockets and go from there.
