  #1
Old 03-04-2010, 09:12 PM
5.0Flareside's Avatar
5.0Flareside 5.0Flareside is offline
OP of 1st PWT
5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute
Brake light and reverse light wiring problem
well a few days ago i posted about having no reverse lights on the 88. well now it has only 1 brake light again.. this had happened a few months ago so i replaced all the bulbs. well now it has happened again.. i havent got the chance to really pull it apart and check anything but i got a circuit tester to check if im getting power to the connectors in the socket. if i am then i know its a bulb connection problem... but the only problem with that is the parking lights work.... but if not that means a short circuit somewhere or ground problem. cause all the fuses are fine. but first off what should i hook the aligator clip on the circuit tester too? aint it gonna be a ground? but any more tips?
Chris C.
94 F250 7.3 Powerstroke ZF-5.
PREVIOUS: 92 F150 Flareside(white), 87 F250, 92 F150 Flareside (supercab & Red), 88 F-150, 82 F100
  #2
Old 03-04-2010, 09:22 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
I normally clip mine to the bumper or the stake pocket.
Click for weather forecast
________________
Randy
  #3
1985 Ford F-150's Avatar
1985 Ford F-150 1985 Ford F-150 is offline
Country Boys Can Survive
1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute
Hook it to a piece of metal and then wiggle it till ya get the light to come on.
Dan
72 F-250 4x4
67 CJ5
86 F-250 HD 4x4
79 Bronco
  #4
Old 03-05-2010, 09:42 PM
OP of 1st PWT
here is the wiring diagram and i dont understand any of it....
not real good with electrical...
Chris C.
  #5
Old 03-05-2010, 10:42 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Ranger Lariat
Fordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond repute
All the circles with squiggly lines are bulbs.Blk is usually ground,and dots at the T's(where one wire meets another) are splices.
Wht=White
LT Blu=Light Blue
Those abbreviations indicate wire colors.Just follow the wires.
Keep in mind the wires could be completely different colors than what the diagram lists.One thing I can say is that the license plate lights use a brown and black wire,it's that way on my 80,and it's that way on a buddy's 95,I don't think they changed those colors.
Shaun
1980 Ford F150 Ranger Lariat
2003 Ford Ranger Edge
  #6
Old 03-06-2010, 03:53 AM
A_G's Avatar
A_G A_G is offline
wuh?
A_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud ofA_G has much to be proud of
yep looks like your looking for a Black and apink wire going to your rear back up lamps, and a black wire ground, So check the ground.
and ont he brake lights
Light green and a orange, going into the lamp and black gorund, with brown running out .
the righ tone is, light blue and orange.
Good luck, Have fun
1998 F150 std cab swb 4x4 5.4 - The Daily Driver
1967 f250 352ci - I may finish this one day
1979 toy 4x4 - The project
1988 toy 4x4 - The donor
1988 rx7 na - Totaled
2013 Yamaha FZ8
  #7
Old 03-06-2010, 03:43 PM
OP of 1st PWT
ok ive got the tail lamps apart and i was looking for a ground spot and i cant find any ground spot. i have the brake lights fixed but it still has no reverse lights. where would the ground be for the reverse lights.. and if it has a good ground where is the reverse switch?
Chris C.
  #8
Old 03-06-2010, 04:58 PM
smokey's Avatar
hitech hillbilly
Admin
the switch is mounted on the tranny.
________________
Randy
