Go Back   Ford Truck Fanatics > Engines > 4.6L/5.4L/V10 Modulars
Old 02-05-2014, 11:29 AM
shademt shademt is offline
shademt
shademt is on a distinguished road
oil pressure..problem.
I have a F-250 SD..truck has alway's been very reliable. Uses no oil. compression is good for a motor with 260,000 miles. Don't use it much. Oil hasn't been changed like it should have been last year or two.
Anyway used the truck like a month ago hauled a couple loads of wood..No problems..everything was ok. Parked it got a cold snap temps below zero.
Went out to start it..no oil pressure. Left it warm up. pressure went up. drove the truck. Pressure dropped back down at idle.
Put in a new oil sensor and changed oil. Pressure goes up at start up..drops back down at idle.
Engine seems noisier once it warms up. So i'm thinking it's not getting enough oil in the top of motor.
What baffles me is why all of a sudden? It almost seems like the cold had something to do with it?
I'd hate to pull the motor just to drop the oil pan..look at the pick up screen ect..
It just baffles me why this would all of us sudden happen when it got cold
Old 02-05-2014, 12:47 PM
shademt
trucks an early 99 so probably no cam phasers..and the serivce engine light is not on.
Old 03-05-2014, 05:20 PM
98f150base's Avatar
98f150base 98f150base is offline
98f150base is just really nice98f150base is just really nice98f150base is just really nice98f150base is just really nice
It's easy enough to check oil pressure with a mechanical gauge just so you know what the pressure is at on a warm idle.
  #4
Old 09-25-2014, 05:35 AM
Mcrafty1 Mcrafty1 is offline
Mcrafty1 is on a distinguished road
OP must of died? 6 months and no more posts.
Allan 2007 F350 CCSB lariat, 118,000 mi. Stock 6.0, <10* deltas, Sinister Water Filter, ScangaugeII, Wolverine Oil Pan Heater and HFCM Drain Plug Upgrade, Blue Spring installed, Thermostat installed.. coolant change completed.2007 SDSC XL 5.4l 3V 68,000
