  #11
Old 08-08-2017, 06:37 PM
dustybumpers's Avatar
owned by Fords
I have never been so lucky as to get a tank to wiggle out of the frame, and past the hitch. I've pulled a whole bunch of them.
Maybe your truck is somehow different. I hope for your sake anyway, as it really sucks pulling the hitch with the gas tank flopping around in there......
one thing to do while the tank is out,
Check the fitting on top of the rubber brake hose where the steel brake line goes in ( off the rear)
Now is the time to replace that line if it is in need of repair.
Charlie
  #12
Old 08-08-2017, 06:59 PM
fatherdoug's Avatar
That is NOT what I wanted to hear! This job will probably have to wait until I can get some help. I did pull all the strap bolts one at a time and chase the threads so they will just thread on with my fingers.
I did notice that brake connection and wondered about that. Thank you, Charlie.
'78 F-150 Lariat
Quote:
Quote:
  #13
Old 08-09-2017, 07:00 AM
owned by Fords
If your going to change out the tank.......
Bronco's had a 35 gal tank. get the pump, hanger, and fuel gauge assy
You also need to either make your own fuel tank straps, or go to the junkyard and find a Bronco with a skid plate/ tank bracket
You will lose the ability to carry a spare, BUT, if you are pulling a trailer with a 460, that extra fuel comes in handy.......
Charlie
  #14
Old 08-09-2017, 07:03 AM
owned by Fords
BTW, you do know that you can pump the gas out of the tank into 5 gal buckets to make it easier to handle, right?
Charlie
  #15
Old 08-09-2017, 08:36 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
I agree with Charlie you will probably have to take the hitch off. I removed a few and thought it will squeeze past but alas I ended up dropping the hitch after alot of unsavory words.
Click for weather forecast
________________
Randy
  #16
Old 08-09-2017, 10:28 AM
fatherdoug's Avatar
True.
Yes, the tank has a couple of gallons in it.
Quote:
I like unsavory words! Thank you, both.
'78 F-150 Lariat
  #17
Old 08-09-2017, 05:37 PM
owned by Fords
Good to take the hitch off, and look for cracks anyway
( keep telling yourself that, maybe you'll believe it)
Good time to clean and undercoat places you can't get too
( there went the simple project)
Charlie
  #18
Old 08-09-2017, 08:35 PM
fatherdoug's Avatar
Thank you, Charlie. I've got to take the hitch to check for cracks, anyway.
'78 F-150 Lariat
  #19
Old 08-10-2017, 08:07 AM
Fellro's Avatar
Fellro Fellro is offline
Admin
The bolts might be stressed, so replace them...
I happen to have a Bronco tank, but have to watch them as well, as some were nt fuel injected so be sure to get one that is... I got the one I have for a diesel so it didn't matter. I did install the 38 gallon aftermarket though. The downside of it is they don't make a sender and pump hanger to go with it. Again, this one was for a diesel, and trying to remember now if it had the big hole for the pump or not. I did have the hitch on, and yes it was a not nice word to deal with. I ended up folding the tank lip down to get clearance. What they do for the straps is simply use pipe spacers and either long bolts or threaded rod. Been up there for several years now... I also undercoated the tank before installing it.
My trucks:
  #20
Old 08-10-2017, 11:20 AM
fatherdoug's Avatar
Thank you, Roger. One step forward and two steps back...........
'78 F-150 Lariat
