  #21
Old 06-26-2017, 10:12 PM
Kaajot Kaajot is offline
Kaajot is on a distinguished road
Arrow The 6.0 Update Fix
Hi all-
We put the new ECM in -- it now runs just fine, although there is a check engine light still and we cannot get the KOER to run. It pauses after initial setup and says "Cannot detect Injector" or something like that. I did not take a picture of the print out.
It does not even start going through different rpms or get to pumping the break, steering the wheel, etc. It literally cannot detect something and hangs there.
Could this have something to do with calibrating the EEC-IV?
As stated, it's running pretty well so far. I'd dare say it's running almost as good as when I first picked it up.
Also, the old ECM did have a busted capacitor. So that was the correct diagnosis. The TPS, IAC, Coolant Temp IAT, etc are all reading correctly now.
Ideas about how to fix so we can pull the remaining engine codes from KOER?
  #22
Old 06-27-2017, 09:27 AM
Edit:
Error code came to me in a dream -- yeah, it bothers me that much.
The scanning tool on KOER goes through the "set-up" process ie get up to temp, turn off engine, leave off 10 seconds, turn back on, etc and then displays the following message that it is hung up on and does not go through with the KOER test.
"Cannot detect Cylinder #"
This is after a new ECM install and oil change and I'm 100% confident the oil didn't do it.
Ideas?
  #23
Old 06-27-2017, 11:43 AM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
i sent a pm to someone that use to frequent the forums in hopes maybe theyll pop in to offer suggestions.
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #24
Old 06-27-2017, 08:52 PM
bigun bigun is offline
bigun is on a distinguished road
The current L6/V6? I don't understand this?
Although the E40D is a much better and stronger transmission, the AOD is great under the right set-up. When the AOD was installed was the mechanical "kick-down" linkage installed?
This linkage is not for passing gear as most people think(including some mechanic's) this linkage preset's the line pressure needed for correct shifting.
  #25
Old 07-01-2017, 01:19 AM
Arrow
I don't think so. That would have required thinking very hard. When we pulled the engine 21ish days later because it was running like crap the flex plate was cracked in a perfect circle and the bell housing was broken at the top mounting location.
The mechanic was not very observant of what he was working with and how he was doing it. As far as I know, I never saw a kick-down linkage to the AOD. I know the old Electronic plug from the engine or harness (wherever it comes from) was zip tied or taped on the top side of the transmission because there was obviously no connection point coming from the AOD transmission.
What's the kick-down linkage look like?
Neither here nor there, except if I take the guy to court over it, as it won't change anything that an E40D is now installed and running well.
  #26
Old 07-01-2017, 01:20 AM
Quote:
Thanks Sparky -- any help is appreciated about the Cylinder # detection problem.
ALSO:
Anyone know if the tube coming off the Cat converter to the EGR Tube is able to be purchased separate for a 4.9L straight 6 300?
  #27
Old 07-02-2017, 04:20 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
stalling
the coolant temp reading -40 means that the coolant temp sensor is disconnected (or the pcm "thinks"it is)with that reading the pcm will make adjustments in timing, injector duty cycle in an attempt to "warm it up". Theres where your fuel is going. if you create a massive vacuum leak, you'll get stalling just like you have. looking at a scanner, look at lft (long fuel trim) that's the adjustment that the pcm makes to compensate for a vacuum leak. ideally you want that reading around 0
ase master tech--fmc senior master tech (retired)
  #28
Old 07-03-2017, 09:02 AM
Quote:
Thanks blacksnapon!
Yeah, we had a -40 when they pulled it and didn't reconnect it. Reconnected and it ran fine. PCM (ECM/EEC-IV?) (Primary Computer Module?) is working if that's all the same thing. I know ECM/EEC-IV are used interchangeably on this generation.
It's showing the correct temps now. I'll check for the LFT (didn't see it with the tool we were using, but we're using the mechanic next door's computer to pull codes next and will monitor for a 0 reading, else we'll know we still have problems causing a loss of gas).
Good news on that front - after oil change, no smell of gas mixing in the oil so far after 200 miles of driving. Hoping the next 800 is just as clean.
  #29
Old 07-03-2017, 11:14 AM
Super Moderator
Super Moderator
Quote:
Originally Posted by Kaajot View Post
Thanks blacksnapon!
pcm is powertrain control module
  #30
Old 07-03-2017, 11:19 AM
Super Moderator
Super Moderator
as far as the cannot detect cylinder#, look at the crankshaft position sensor on the front pulley. it will Read off of the "star" wheel that is attached to it. perhaps it isn't plugged in or a broken wire or damaged lower pulley.
