Go Back   Ford Truck Fanatics > Special Interest > Off-Road
  #11
Old 05-15-2017, 07:29 PM
77mud's Avatar
77mud 77mud is offline
77mud has a spectacular aura about77mud has a spectacular aura about
Tonight I got out there and put the transgo shift kit in the C6 VB. I'll put the VB back on the trans sometime this week aswell as get the crossmember moved, hope to have the transmission bolted in the truck this weekend.
Larry
01 SuperCrew 5.4
95 F350 CC LWB 7.3
77 F150 Ol' Blue mud truck on 38.5s
92/6 F150 Project reincarnation aka "Lil Mrs. Blue
  #12
Old 05-15-2017, 08:34 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Nice progress Larry, that Offy manifold is sweet.
Quote:
Quote:
Quote:
  #13
Old 05-17-2017, 05:53 PM
77mud's Avatar
Thanks!
Well I got the transmission crossmember trimmed, and bolted in today. Hope to have the transmission in, and maybe even set the cab on this weekend... maybe...
Also a new goodie showed up tonight.
Larry
01 SuperCrew 5.4
95 F350 CC LWB 7.3
  #14
Old 05-17-2017, 07:40 PM
DNFXDLI's Avatar
Admin
Do I spy a spool?
  #15
Old 05-18-2017, 04:00 AM
77mud's Avatar
Yup, going with the same 9" full spool I switched to in my 77 after the Mini split in half a couple years ago. Figured I'd just skip the Mini step with this one.
Larry
01 SuperCrew 5.4
95 F350 CC LWB 7.3
  #16
Old 05-20-2017, 06:17 PM
77mud's Avatar
Well transmission is officially in and bolted to the engine.
Tomorrow morning the plan is to setup the 9" housing with the spool. Then once I am able to get a little help I hope to try and set the cab on the frame.
Larry
01 SuperCrew 5.4
95 F350 CC LWB 7.3
  #17
Old 05-21-2017, 12:13 PM
77mud's Avatar
Well I was able to get a little help fairly early this morning, so I got a little somewhere with the truck.
Cab is in place, just need to snug it down. I didn't get to the rearend because when I pressed the bearings on, they decided to self destruct so I got fed up with it and set it to the side.
Larry
01 SuperCrew 5.4
95 F350 CC LWB 7.3
  #18
Old 05-22-2017, 05:32 PM
77mud's Avatar
Got the spool in and setup, new pinion seal aswell. Axle is officially ready to be bolted in whenever I get around to it.
Larry
01 SuperCrew 5.4
95 F350 CC LWB 7.3
  #19
Old 05-29-2017, 02:39 PM
77mud's Avatar
Got the 8.8 and stock leafs out, and the 9" and 4" lift back in.
Jacked up to get the 8.8 out
She gone.
And the 9" with 4" lift bolted back in.
Larry
01 SuperCrew 5.4
95 F350 CC LWB 7.3
  #20
Old 05-30-2017, 08:25 AM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Jasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to behold
Moving right along, nice!
- Russell
'77 F100 Flareside
