  #51
Old 09-07-2016, 09:55 AM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
Quote:
We're just really good listeners.
Married men everywhere.
  #52
Old 09-10-2016, 09:32 PM
welderr welderr is offline
welderr is on a distinguished road
I did a little googleing and came up with this. I have axle code 29, (Thanks Miranda, I never knew about axle codes) My truck has a 5 speed with a inline 6. Do any of you think I will have a issue finding solid axle with that gear ratio?
29 3.55 5300 FORD REG 1991
  #53
Old 09-17-2016, 08:13 PM
Any body here ever pop out the engine cradle and swap it to another frame? Anyone?
  #54
Old 09-17-2016, 11:21 PM
fatherdoug's Avatar
The axle ratio is listed next to the code, which is a 3.55. Solid axles with that ratio would be very common.
'78 F-150 Lariat
Quote:
Quote:
  #55
Old 09-18-2016, 07:39 AM
Thanks for the info. I have only visited 1 yard. Will keep looking. Thanks
  #56
Old 10-03-2016, 09:15 PM
primetime's Avatar
primetime primetime is offline
sawmill slave
primetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond repute
Why would you want to do that?
________________________________________
Justin
With a little luck and a greenback dollar you gonna see me shine.
  #57
Old 10-03-2016, 09:27 PM
primetime's Avatar
sawmill slave
Nevermind, figured it out. A Dana 60 is probably a lot easier then swapping the crossmember, and is what I would do. Not that the TTB is a bad thing, it does fine for the majority of use, especially if your primary use is towing, street use, two tracking, and you don`t plan on lifting it with huge tires.
Justin
  #58
Old 07-22-2017, 10:50 PM
Quote:
Not much luck finding a dana 60 front axle. I am not going to put huge tires on it. And it won't be a daily driver. I just want a fun fwd pickup. I drive a different brand as my daily driver, any wheres from 2 wheel drive to 8 wheel drive when I lock in the axles.
There has been a few delays in this project. Job change, work and more work. I think I can start back up on this in a few weeks. Just going to change the cradle out and be done with it.
Thanks for your input.
Mark
  #59
Old 07-23-2017, 08:59 PM
primetime's Avatar
sawmill slave
You should take a look at swapping in Super Duty axles. The rear seems to be pretty much a bolt in. In the front, you will need F-350 springs, or use Super Duty springs. Which will either require a shackle reversal for the front, which will lift the truck, or move the front shackle ahead, because Super Duty springs are longer, which improves the ride.
Either way, with that F-150 frame, you have some work ahead of you.
Justin
  #60
Old 07-23-2017, 09:16 PM
primetime's Avatar
sawmill slave
Two examples.
http://www.pirate4x4.com/forum/ford/...thout-rsk.html
http://www.pirate4x4.com/forum/tow-r...axle-swap.html
I have a 97 Dana 60 and F-350 springs in my F-250. The ride sucks. But I don`t want to lift it any higher than it already is because it`s to tall for my 5th wheel trailer as it sits. So option 1 is what I will be going with as soon as I get some springs.
Justin
