Go Back   Ford Truck Fanatics > Special Interest > Body Work and Paint
  #21
Old 04-17-2015, 10:50 PM
jebadiah04 jebadiah04 is offline
Rooster Snorkler
jebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud of
But that blue is exactly what my truck looked like. To a t
1985 f-150 flareside
2008 f-150 crew cab
2005 f-350 Crew Cab Long Box diesel - for sale. Check out my classified post!
  #22
Old 04-17-2015, 10:55 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
There is a fine line between wet and runs (Insert jokes at will)...
Humidity plays into it some, temperature plays in big time, what speed hardener are you using and what's your temps been while painting?
Пробковыйy
  #23
Old 04-17-2015, 11:01 PM
1970Custom's Avatar
They call me Spuds
How's that buffer working? Better than that orbital I'm going to assume.
Пробковыйy
  #24
Old 04-17-2015, 11:55 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
what temp reducer are you using?
Looks like the reducer is evaporating to fast resulting in the paint not leveling and the gun could be a bit out of adjustment with a little to much air.
Spray a test spray on a peice of white paper the pattern should be a solid long skinny oval that is mostly solid if I isn't a dust the screws till you get a nice pattern.
Click for weather forecast
________________
Randy
  #25
Old 04-17-2015, 11:56 PM
Rooster Snorkler
Oh way better. All.I have left to do is buff out some stratchest then done
2008 f-150 crew cab
  #26
Old 04-17-2015, 11:57 PM
Rooster Snorkler
I don't remember what hardener I used. Was like 2 years ago I painted it. Lol
2008 f-150 crew cab
  #27
Old 04-18-2015, 12:20 AM
1970Custom's Avatar
They call me Spuds
The usual rule if thumb is. 50 and below use a fast hardener, 50-80 use a medium hardener, and above 80 use a slow hardener.
What gun you using?
Пробковыйy
  #28
Old 04-18-2015, 03:39 PM
Rooster Snorkler
Looking down on the hood after the 2nd run on the buffer. I need to take my Christmas lights down
2008 f-150 crew cab
  #29
Old 06-02-2015, 08:15 PM
xroad xroad is offline
xroad is on a distinguished road
You are almost there. What buffer machine are you using by the way and what pad?
  #30
Old 09-03-2016, 06:45 PM
adtkart adtkart is offline
adtkart is on a distinguished road
I just noticed the date on this post but will respond anyway incase someone else needs the information.
As a general rule, orange peel (when the surface looks like an orange) is the result of the paint not being atomized properly. That means that there is too much liquid and not enough air pressure. If you are getting that with single stage or clear coat you can often get by with more coats and then a lot of wet sanding it smooth and buffing. If it is clear, and you sand too far, if the base is metallic, you could have problems because the base will need to be resprayed. Spraying more on top will not smooth it out. That will only make it worse.
