Go Back   Ford Truck Fanatics > Special Interest > Body Work and Paint
  #11
Old 04-17-2015, 07:00 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
That is some nasty orange peel you got there. Looks like you used the incorrect reducer or possible the gun was set wrong.
Sanding and buffing is your only option other than stripping it and starting over.
Click for weather forecast
________________
Randy
  #12
Old 04-17-2015, 07:04 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
He's getting there, just wrapped up a quick text conference pointing him in the right direction.
Пробковыйy
  #13
Old 04-17-2015, 10:10 PM
jebadiah04 jebadiah04 is offline
Rooster Snorkler
jebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud of
It's looking much better. I need to figure out wtf the issue is before I continue with painting.
1985 f-150 flareside
2008 f-150 crew cab
2005 f-350 Crew Cab Long Box diesel - for sale. Check out my classified post!
  #14
Old 04-17-2015, 10:15 PM
1970Custom's Avatar
They call me Spuds
Can you get some direct sunlight photos? From at least a couple angles. Or explain in detail what exactly it looks like.
Пробковыйy
  #15
Old 04-17-2015, 10:19 PM
1970Custom's Avatar
They call me Spuds
You said it's single stage. I'm guessing you sprayed it dry, or basically massive orange peel...
I zoomed in on that first picture and that's my best guess.
Пробковыйy
  #16
Old 04-17-2015, 10:25 PM
Rooster Snorkler
Eric talked me into a legit buffer. After a trip to hf and 1 run on the hood with it and a "rough" pad, and this is where it's sitting now.
Its dark out but you can see the reflection of the garage door now. Getting way better. Still work to do
2008 f-150 crew cab
  #17
Old 04-17-2015, 10:26 PM
Rooster Snorkler
Here's the photo.
Eric what do you mean by spraying it dry?
2008 f-150 crew cab
  #18
Old 04-17-2015, 10:45 PM
1970Custom's Avatar
They call me Spuds
Looks much much better...
When spraying clear coats and single stage, it needs to go on "wet", almost to the point of running. Dry spray is basically applying it too light. Can result in gnarly orange peel or thin or no coverage of material.
Пробковыйy
  #19
Old 04-17-2015, 10:46 PM
Rooster Snorkler
Ok. Yeah I put it on fairly light. Next time I'll hog it on there and see what happens. The roof is next. At least it's not super visible. Haha
2008 f-150 crew cab
  #20
Old 04-17-2015, 10:49 PM
Rooster Snorkler
Another thing I have to deal.with here is high humidity. It's always pretty humid here except for 2 months or so. I wonder if that is what's getting me?
2008 f-150 crew cab
