Go Back   Ford Truck Fanatics > Special Interest > Off-Road
  #11
Old 02-27-2015, 03:02 PM
fatherdoug's Avatar
I agree. Those headlights in the higher temperature ranges are pretty annoying.
'78 F-150 Lariat
Quote:
Quote:
  #12
Old 02-27-2015, 07:34 PM
Austin's Avatar
Austin Austin is offline
Austin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond repute
I absolutely loved my Rigid lights; had a set on the Bronco. Fantastic light output and solid build quality - I will not purchase any other brand for off road lighting.
Quote:
Everyone is my teacher. Some I seek. Some I subconsciously attract. Often I learn simply by observing others. Some may be completely unaware that I'm learning from them, yet I bow deeply in gratitude.
  #13
Old 02-27-2015, 08:22 PM
fatherdoug's Avatar
Good to hear. Thank You, Austin.
'78 F-150 Lariat
  #14
Old 03-11-2015, 09:15 PM
fatherdoug's Avatar
I ordered a pair of Rigid lights tonight, along with some clear polycarbonate covers.
'78 F-150 Lariat
  #15
Old 03-15-2015, 04:13 AM
fatherdoug's Avatar
Lights and covers will be here Monday. Woot Woot!
'78 F-150 Lariat
  #16
Old 03-15-2015, 09:03 AM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Very cool Doug!
Quote:
Quote:
Quote:
  #17
Old 03-17-2015, 02:59 PM
fatherdoug's Avatar
Trying to develop a plan on where to mount everything. Since the switch leads and the battery leads are only 4', I think I will mount the relay(common connection between the battery leads and switch leads) on the firewall in the middle somewhere.
The light leads themselves are 10', so I should have enough wire to get to each light from the relay, and still keep things tucked out of the way.
Since I don't really want to cut a 3/4" hole in the dash, I'm thinking about cutting an access hole in the front of the ash tray, then cutting another hole in the back of the ashtray to run the wires. I already have a spare ash tray(same color) that I can replace if this doesn't work out.
I'm also thinking about mounting the lights themselves on top of the bumper guards. The metal is thick enough so a 5/16" hole drilled into the top of the guard won't ruin the integrity of the guard. That will also get the lights a little farther off the ground. This should be an advantage, both for protection and for aiming purposes.
'78 F-150 Lariat
  #18
Old 03-17-2015, 03:09 PM
m78's Avatar
m78 m78 is offline
m78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond repute
Will you get glare from them if they're higher ? Do you want measurements to where the factory fog light holes are on the bumper ?
On one of my boats, I didn't want to drill any holes so I took that stick epoxy and epoxied the side of the switch to under the dash where it was easily accessible.
Mark
  #19
Old 03-17-2015, 03:11 PM
fatherdoug's Avatar
Good idea, and I didn't think about the glare.
And, sure, if you're willing to provide it.
'78 F-150 Lariat
  #20
Old 03-17-2015, 03:16 PM
m78's Avatar
m78 m78 is offline
Looks like it's 3.25" c to c from the top bumper bolt to the hole . Holes to the outside.
I'll get a picture.
Mark
