Go Back   Ford Truck Fanatics > Special Interest > Off-Road
  #21
Old 08-17-2013, 11:34 AM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Quote:
Originally Posted by slmann View Post
this should be a cool build thread.
was that accessory outlet a factory option or an aftermarket mod?
I was going to ask the same thing
Quote:
Quote:
Quote:
  #22
Old 08-17-2013, 12:04 PM
slmann's Avatar
slmann slmann is offline
slmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond repute
Quote:
great minds think alike.
2010 F-150 STX 4X4
  #23
Old 08-17-2013, 12:16 PM
nobodyspecial's Avatar
nobodyspecial nobodyspecial is offline
Fire in the hole...
nobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond repute
The 221 is the smallest of the Windsor V8s. Unfortunately, it does not share the same bellhousing pattern. Finding a truck type 4 speed for it may be difficult. The 351W that I have would bolt up nicely to the NP435/NP205 combo I have...
Psalm 144:1
Stand your ground. Don't fire unless fired upon, but if they mean to have a war, let it begin here. - CPT Parker - April 19th, 1775, Lexington
  #24
Old 08-17-2013, 01:13 PM
Fire in the hole...
I love the smell of gear lube in the morning.
This will be the new front axle for the CJ. I will be regearing it to 3.73 and adding some kind of traction device, to be figured out later.
I am going to be removing all the Jeep mounts, and setting it up for spring over leafs.
Psalm 144:1
  #25
Old 08-17-2013, 01:18 PM
DNFXDLI's Avatar
Admin
Yes they do.
Is that a Dana 30?
  #26
Old 08-17-2013, 01:35 PM
Fire in the hole...
Yes sir!
It will be matched up with the disc brake 8.8 from my Mountaineer. I will be using the 16" wheels and 33x10 BFG KM2s from the Mountaineer as well.
Psalm 144:1
  #27
Old 08-17-2013, 02:36 PM
LEB Paul's Avatar
LEB Paul LEB Paul is offline
I like Broncos
LEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond reputeLEB Paul has a reputation beyond repute
Needs d44 minumum if you're adding a "traction device" IMO.
Don't think Kris has a thread on his, no build really. All stock as far as I know.
Frame rail width could present a problem on transfer cases and limit selection.
Engine compartment is tiny from what I remember.. 302 is probably going to be tough to fit, let alone 351w... but a nice roller efi 302 would make for a good trail/all around motor IMO.
www.lefteyeblindracing.com
Contact us via facebook, phone, or email:
www.facebook.com/leblind
843-560-2697 payment.LEB@gmail.com
  #28
Old 08-17-2013, 02:56 PM
Fire in the hole...
No D44 needed. With 33" tires, and an lightweight rig, after the D30 is trussed, it will hold up just fine. What kills D30 R&P is housing deflection. Once the housing is stiffened up, they hold together nicely for lightweight small tire rigs.
As far as 351 vs 302, there is a very small difference in size between them, and only like 75 lbs I believe. I have a 79 302, but it would need machine work, as it overheated and possibly warped a head. On the other hand, I have a used, but well running 351W just sitting in the shop...
As far as it fitting, people have put a lot bigger engines in CJs than a 351. It can be made to work.
Psalm 144:1
  #29
Old 08-17-2013, 04:41 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
I'd go 351w and be done... You'd never wonder what it would be like with more power
What happens to the mountaineer then?
-Frank
Quote:
What's your view on sheep?
  #30
Old 08-17-2013, 04:54 PM
Fire in the hole...
You will just have to wait and see...
Psalm 144:1
