  #1
Old 06-29-2011, 09:51 PM
F 150Cobra's Avatar
F 150Cobra F 150Cobra is offline
"Wild HoRsE" Got Torque?
F 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant future
Brakes help
going to pass inspection soon
the brakes pads in the front are new the wheel cylinders in the rear are new with good brake shoes.. now when testing the brakes today ive noticed the truck pulls a little bit to the right but only when mashing the pedal really hard and skids.. doesnt pull when doing normal braking.. what can be done to get all brakes working the same???
Jurgen
F150 1990 blue thunder
F250 1996 Frankenmonster
Bronco 1994 (dad's ride)
Lightning 1994 (restoring)
Aruba.
  #2
Old 06-29-2011, 09:56 PM
73F100Shortbed's Avatar
73F100Shortbed 73F100Shortbed is offline
73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute73F100Shortbed has a reputation beyond repute
Could be that the brakes are not adjusted evenly in the rear, or a brake hose in the front is starting to collapse internally not letting the fluid return as quick as it should. Also check that your pads move freely and check your calipers.
Sean
1973 Ford F100: 302, 3-speed, dual exhaust with glasspacks
New Jersey Chapter Leader:Click here to Join
Click for Woodbridge, New Jersey Forecast
  #3
Old 06-29-2011, 10:18 PM
F 150Cobra's Avatar
Quote:
rear brakes can cause the truck to pull to the side?? im in the process of adjusting the foot ram and it grabs the right side more than the left tomorrow im gonna re adjust
Jurgen
Aruba.
  #4
Old 06-29-2011, 10:20 PM
I would check the front first. I've seen it a couple of times in the rear. Not often but it's worth checking. How do they check them during inspection? Here in NJ they would hit skid plates and give a chart of the pressure applied on each wheel. If something was out of whack you could see where the problem was.
Sean
  #5
Old 06-29-2011, 10:33 PM
F 150Cobra's Avatar
same thing here..
ok im gonna bleed the fronts tomorrow and adjust the rear and double chek it i suspect its the rear becuase i never had this prob before it came when i started to change the wheel cylinders and adjust the foot brake
Jurgen
Aruba.
  #6
Old 11-05-2017, 10:42 PM
Blacktruckdave's Avatar
Blacktruckdave Blacktruckdave is offline
Blacktruckdave is on a distinguished road
old thread but what ever was the problem. I am hunting down a front pull when I hit the brakes.
  #7
Old 11-30-2017, 04:19 AM
Kaajot Kaajot is offline
Kaajot is on a distinguished road
Question
Quote:
Nice Necro.
Did you figure it out? Since you know, we didn't get any info on what's going on with your brakes, other than a front pull.
If you know it's front, there's half your battle. Now is it left or right? And that's the side you open up and check for pads or a sticky/locked caliper or....
I dunno. I just replace my pads and rotors and A12/13 bearings -- sometimes my calipers (did those in 2009, they're still good). ^_^ Brake bleeds are no fun, so glad my calipers are champs.
  #8
Old 11-30-2017, 10:29 AM
I didn't figure it out completely yet. Right rear top caliper pin was stuck. Cleaned and re lubed both sides. Still pulls a little to the left when hard braking but not as bad. I was told in another thread that the pads in the back were wearing in. Keep ya posted.
