  #21
Old 08-10-2017, 10:22 PM
fatherdoug's Avatar
Started on the rear gas tank at about 10:00 this morning and just finished up. I'm sure glad I removed the hitch before dealing with the tank. I also had to pull the exhaust pipes out a little ways with a ratchet strap in order for the tank to clear the pipes.
I'm glad I had help, also. I don't think I could have put that tank back up in there, since you don't have a lot of room to reattach the fuel lines and vent lines.
I will take the truck for a little drive tomorrow after I replace the throttle body gasket.
Once again, thank you everyone for the help and suggestions!
'78 F-150 Lariat
  #22
Old 08-12-2017, 07:00 PM
fatherdoug's Avatar
Success! Took the truck for a good drive today. No hesitation, stumbling, farting or anything else. I switched tanks numerous times and also did some heavy acceleration with no problems. Now if I can just get the mpg above 8.......
'78 F-150 Lariat
  #23
Old 08-12-2017, 07:30 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
The heavy acceleration won't help the fuel mileage
Glad you're up and running again Doug
-Frank
What's your view on sheep?
  #24
Old 08-12-2017, 07:54 PM
fatherdoug's Avatar
I thought if I could get there quicker, it would use less gas.
'78 F-150 Lariat
  #25
Old 08-14-2017, 05:58 AM
dustybumpers's Avatar
owned by Fords
I bet if you put it on a rollback the gas milage will bump right up!
Glad you have it running "like new" again
Charlie
  #26
Old 08-14-2017, 08:09 AM
fatherdoug's Avatar
The rollback would cost more than 8 mpg!
'78 F-150 Lariat
