Go Back   Ford Truck Fanatics > Engines > 289, 302, 351W
  #1
Old 12-25-2014, 11:44 PM
justinhill7714 justinhill7714 is offline
justinhill7714 is on a distinguished road
302 dying at warm highway speeds
I have a 1978 F150 with a 302. I replaced the starter and battery. My problem is when the truck warms up, and I'm going moderate speed (50 mph), the engine sputters, jumps, and then dies. I will take anywhere from 10 to 20 minutes to get it to turn on. Please help so I don't drop tons of money into stuff I won't need.
Thanks
  #2
Old 12-26-2014, 06:17 AM
fatherdoug's Avatar
Coil or engine control box on driver's fender?
'78 F-150 Lariat
Quote:
Quote:
  #3
Old 12-26-2014, 06:32 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Click for weather forecast
________________
Randy
  #4
Old 12-26-2014, 09:11 AM
Thanks guys. Going to replace today or tomorrow. Let you know how it goes.
  #5
Old 12-26-2014, 10:11 AM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
When it dies, check to see if you are getting fuel by looking down the carb and pulling on the throttle linkage...it could be the module like the other guys said but you might be having a fuel delivery problem as well.
I had a 78 Bronco that did this and it was fuel.
Quote:
Quote:
Quote:
  #6
Old 12-26-2014, 11:05 AM
jebadiah04 jebadiah04 is offline
Rooster Snorkler
jebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud of
Definitely make sure when it dies that the accelerator pump is squirting fuel. My k5 did that. Took me a while.to figure out.
Next thing I'd check is the ignition module then coil. Just take them off and run into oriellies or such and they will test for free. Make them test a few times so they warm up since it's failing when warm
1985 f-150 flareside
2008 f-150 crew cab
2005 f-350 Crew Cab Long Box diesel - for sale. Check out my classified post!
  #7
Old 12-26-2014, 12:13 PM
Appreciate the comments. Thanks again
  #8
Old 12-26-2014, 12:47 PM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
a bit late to reply but my old truck did this and it was the ICM, $45 at Napa to replace.
Roy
yeeooow!
  #9
Old 12-26-2014, 01:07 PM
This is what I'm looking at. Which part exactly?
  #10
Old 12-26-2014, 01:11 PM
amkatt1's Avatar
It's the ignition control module that is mounted on the inside fenderwell on the drivers side. Has 2 plug-ins leeds. Gray/silver color box
Roy
yeeooow!
