Go Back   Ford Truck Fanatics > Engines > 289, 302, 351W
  #21
Old 08-24-2014, 05:43 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
When you installed the crank....did use use a plastigauge or dial indicator?
Quote:
Quote:
Quote:
  #22
Old 08-24-2014, 05:45 PM
m78's Avatar
m78 m78 is offline
m78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond repute
Quote:
Originally Posted by 1970Custom View Post
I did, sorta, and they were numbered; BUT, I got dyslexic and flip flopped them. Had them snugged up but not torqued when I caught it.
And you say the tabs should be together, not on each side of the journal????????
Doesn't the block and caps have grooves cut in them for the tabs ?
It sounds like one of the bearings spun to me.
Mark
  #23
Old 08-24-2014, 05:51 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
Quote:
Yeah, sure, maybe....
They do, and I did install those properly, I am certain that's where #### went awry....
Пробковыйy
  #24
Old 08-24-2014, 05:54 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
So, what you do, is take a piece of plastigauge, which is getting hard to find these days, but parts stores still have it sometimes, and place it between the bearing and the crank, then you tighten the cap down, torque it, then take it back apart. You then measure the width that it smashed down to to find your clearance. The plastigauge comes in different colors to denote the size clearance you are trying to adjust for. One key thing, do this one cap at a time, and do NOT rotate the motor. (That is actually on the instructions! Obviously someone has!)
My trucks:
  #25
Old 08-24-2014, 05:56 PM
DNFXDLI's Avatar
Admin
That might be part of the problem....you need the correct clearance between the journal and the bearing..it's just an oil film that separates and lubricates...too tight and you have issues, too loose and you have issues.
Have a read:
http://underthehood.mahleclevite.com/?p=618
  #26
Old 08-24-2014, 06:02 PM
1970Custom's Avatar
They call me Spuds
So, with that link, Clevite or Sealed Power?
Пробковыйy
  #27
Old 08-24-2014, 06:04 PM
DNFXDLI's Avatar
Admin
Huh? .
  #28
Old 08-24-2014, 06:14 PM
1970Custom's Avatar
They call me Spuds
Bearings. Which brand.
Пробковыйy
  #29
Old 08-24-2014, 06:16 PM
Fellro's Avatar
Admin
Both are reputable, I have no issue with either. (Had me scratching my head too... )
My trucks:
  #30
Old 08-24-2014, 06:18 PM
DNFXDLI's Avatar
Admin
I don't think you can go wrong with any of the major brands Eric.
I think most of the bearings TMI gave me for my 434 were Durabond and King.
