  #501
Old 04-15-2017, 03:37 PM
taxreliever's Avatar
taxreliever taxreliever is offline
taxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond repute
Quote:
It talks too much.
Quote:
Beautiful, Duncan!
Ken
1977 F150 400 AUTO 4x4
1979 F250 400 AUTO 4X4
2006 F150 King Ranch
2007 Expedition EB
www.taxreliever.com
Quote:
Or, as the great Greek philosopher Testiclees once said: "Man who goes through turnstyle in airport is going to Bangkok."
  #502
Old 04-15-2017, 09:06 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Pretty much got the underside of the front crossmember area all done. The place where the steering damper was attached was somewhat fekked up probably from tagging stuff over the years.
I put some heat on it and used a wrist pin and 2lb hammer to flatten the high spot and then welded a couple of nuts on to the low spot and used a slide hammer to pull it up.
I'm pretty happy with the results.
Quote:
Quote:
Quote:
  #503
Old 04-15-2017, 09:08 PM
fatherdoug's Avatar
Too bad you can't have the frame OUTSIDE the truck.
'78 F-150 Lariat
Quote:
Quote:
  #504
Old 04-15-2017, 09:09 PM
fatherdoug's Avatar
Quote:
Originally Posted by taxreliever View Post
I thought of that, also.
'78 F-150 Lariat
  #505
Old 04-15-2017, 09:11 PM
DNFXDLI's Avatar
Admin
  #506
Old 04-15-2017, 10:58 PM
cbaker65's Avatar
cbaker65 cbaker65 is offline
cbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond repute
Quote:
Originally Posted by DNFXDLI View Post
He could if he didn't install the cab & bed ,just build a roll cage!....
Lookin sweet though!...
CB
Im not a bum,Im on vacation!....
  #507
Old 04-16-2017, 01:03 PM
DNFXDLI's Avatar
Admin
lol and thanks CB
I ordered a set of carbide burrs to do the holes, sanding drum was pissing me off
