Go Back   Ford Truck Fanatics > F-Series > Generation 5
Generation 5 1967-1972 F100, F250, F350
  #11
Old 04-14-2015, 05:01 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant future
Be aware that there were TWO different 9" rear axles used in 1970/72 F100's.
One has a 9" ring gear and 28 spline axle shafts. T'other has a 9 3/8" ring gear, 31 spline axle shafts and Traction-Lok.
9 vs 9 3/8: Only 5 parts are the same: Housing gasket, pinion seal, pilot bearing retainer, one pinion bearing and cup.
EVERYTHING else is different!
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
  #12
Old 04-15-2015, 09:24 AM
Carmack Carmack is offline
Carmack is on a distinguished road
So what would you recomend for the set up im looking for
Tags
1971 f-100
