Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #1
Old 03-21-2017, 05:10 PM
fatherdoug's Avatar
Speaking of Welders......
I'm a newbie...I have welded, but briefly about 40 years ago(Yes, I'm that old).
Would this be a good starter machine?
https://www.amazon.com/MIG-Welder-Ha.../dp/B003TS8D2M
'78 F-150 Lariat
Quote:
Quote:
  #2
Old 03-21-2017, 06:04 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Yes yes it would
Click for weather forecast
________________
Randy
  #3
Old 03-21-2017, 06:40 PM
fatherdoug's Avatar
Thanks for the input, Randy.
'78 F-150 Lariat
  #4
Old 03-21-2017, 07:32 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
Looks good. 240v rather than 120v like most cheaper machines. And if I read it right it will do gas or flux core. Be a good machine
-Frank
Quote:
What's your view on sheep?
  #5
Old 03-21-2017, 07:57 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Lincoln or Hobart are my preference. Can't go too wrong with starting at 240 either. It will be much more user friendly at the higher voltage.
My trucks:
  #6
Old 03-21-2017, 09:53 PM
fatherdoug's Avatar
Thank you, both. That is good to know.
'78 F-150 Lariat
  #7
Old 03-21-2017, 10:25 PM
smokey's Avatar
hitech hillbilly
Admin
Also get a adjustable self darkening helmet. They normally come with a handheld shield. It will work but is some much easier when you can use both hands and not worrying about getting a arc flash.
________________
Randy
  #8
Old 03-21-2017, 10:32 PM
fatherdoug's Avatar
Will do.
'78 F-150 Lariat
  #9
Old 03-22-2017, 06:25 AM
dustybumpers's Avatar
Learn with the gas, it will give you a better weld, and be easier
Flux has to have a CLEAN surface, and is very unforgiving. Welds will not stick, and that is frustrating when just starting out
Make sure to get extra box of tips. and go ahead and buy the big roll of wire.
The small roll don't last as long as you want it too, and is expensive in the long run
Get a tip cleaner.
Have fun, and be safe
Charlie
  #10
Old 03-22-2017, 06:58 AM
Fellro's Avatar
Admin
Definitely on the helmet. I went for many years as a head flipper. With mig you can get away with it better than stick, but once I finally got an auto dark I wondered why the hell I waited so long.
Nozzle dip or the spray is helpful on extending the life of tips and nozzles as well.
My trucks:
