Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #71
Old 03-18-2017, 10:09 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Quote:
I wear nomex underwear.
I could tell you a story.....
Quote:
Quote:
Quote:
  #72
Old 03-18-2017, 10:12 PM
fatherdoug's Avatar
'78 F-150 Lariat
Quote:
Quote:
  #73
Old 03-18-2017, 10:15 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Welding is easy just takes a little time to get used to what amp setting to use.
You will catch stuff on fire from time to time. Wear long pants and a long sleeve shirt if you will be welding any amount of time. You will get a sun burn from the arc.
Click for weather forecast
________________
Randy
  #74
Old 03-19-2017, 03:37 AM
fatherdoug's Avatar
And then I need another 240 volt outlet in the garage. I already have one, but it is powering the garage heater.
'78 F-150 Lariat
