Old 11-26-2017, 06:54 PM
Bax's Avatar
Bax Bax is offline
Bax will become famous soon enoughBax will become famous soon enough
ABS light on, brake problems
ABS light stays on after panic stop with trailer. 70 MPH to 0 as fast as you can. I need some service advice about the ABS system in my 2000 f250. During the stop the light came on and has stayed on. I had major brake fade during the stop. Rotors are now warped , it shutters under breaking. The brakes are no where as good as they were. How do I check out the ABS? The light went out once, I stepped on the brake. The truck pulled hard driver the light went out and it stopped pulling.Just looking for a place to start. Any Ideas?
Thanks
Bax
1968 Bronco 408/c6/205/ARB's/4.88's/37's.
Old 11-26-2017, 11:20 PM
polarbear's Avatar
polarbear polarbear is offline
just growing older not up
polarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond repute
Did you check brake fluid level in the master cylinder? That's the first place I'd start. If it's low, bet the pads need to be replaced.
"Hillbilly Deluxe"
Old 11-27-2017, 06:19 AM
Bax's Avatar
Bax Bax is offline
Thanks for the reply. Yes I did check my brake fluid level. All good there.Brake job about 6 months ago. I had replaced all rotors and pads. Brakes were smooth and in good working order.
  #4
Old 11-27-2017, 10:43 PM
polarbear's Avatar
Did it throw any codes?
"Hillbilly Deluxe"
  #5
Old 11-28-2017, 11:19 AM
dustybumpers's Avatar
If the brakes got hot enough to warp the rotors, I imagine it cooked the sensors too
Like mentioned, have you checked the codes?
Charlie
  #6
Old 11-29-2017, 06:43 PM
Bax's Avatar
Bax Bax is offline
Have not checked for a code yet. I will do that this weekend and post what I find. I dont think it is a sensor. That would be too easy. Sometimes the light will go out. It makes a noise when it does. Much like the noise the transfer case makes when going into low. With the light off if you apply the brake it will pull to the drivers side, then the light will come on and the pull stops. I think something other than a sender is wrong. But you guys are correct, I should start by putting the scanner on it.
Thanks again.
Bax
  #7
Old 11-29-2017, 07:37 PM
Sounds like a toner wheel came loose
Charlie
