1992 4.9 e4od in the f250 part 2
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
Does these trucks has some kind of safe mode? Like it wont go more than 10% load so it dont burn the trans up??
These are the codes i got
637 tot sensor was high
327
654mlps sensor not in park
558 egr valve
621 shift selenoid 1 open
629 tc clutch selenoid failure
627 tc selenoid failure
542 low speed fuel pump failure (no tin)
624 epc failure
626epc current is low
Either a bad harnass or bad mlps and selenoid pack ?
check fuses and the connector into the trans for corrosion and/or water intrusion. You're losing power to the trans and that defaults it to second gear.
F 150Cobra
3,642
104
Aruba
Yessss correct only 2nd gear works!
F 150Cobra
3,642
104
Aruba
Ok gonna chek all relays first then chek full harnass
Its an 1992 harnass engine trans we installed into an 1996 f250 that was a diesel it starts and works but a few issues
And the other thing it does.. it dies when i give it gas in gear u cannot give it more then 25% throttle it will loose a few cilinders when free rev or and dies in gear .. ( we cheked with another ecu one for a manual and the engine revs fine drove fine in 2nd but maybe its a kind of safe mode so u dont burn up the trans??
F 150Cobra
3,642
104
Aruba
Cleaned all hrnass plugs everything works now thanks!
