  #11
Old 05-21-2012, 08:49 PM
fatherdoug's Avatar
On the 351M/400 there is a dedicated bolt hole for grounding the negative post of the battery to the block. I looked to see if the engine diagram indicated what size bolt was used, but the diagram doesn't show that bolt.
The hole is directly below the alternator at the bottom of the block.
'78 F-150 Lariat
Quote:
Quote:
  #12
Old 05-21-2012, 09:21 PM
thtniggey's Avatar
thtniggey thtniggey is offline
thtniggey is on a distinguished road
Does the hole kind of look like a bracket and sticks off the block a little bit? if so lucky me that part of the blocks broke..
  #13
Old 05-21-2012, 09:33 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Quote:
Quote:
Quote:
  #14
Old 05-22-2012, 09:50 PM
thtniggey's Avatar
Yup my blocks broken there but thank you for the help!!
  #15
Old 05-23-2012, 05:51 PM
Mil1ion's Avatar
Mil1ion Mil1ion is offline
Mil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond repute
The engine start circuit runs through the Neutral start switch which is located in different spots depending on year and type of Trans
The 'Engine keeps cranking' situation is because of power continuing to the S terminal of the relay
This can happen after trying to start an engine with a dead battery. The small amount of power from a low battery can actually WELD the contacts related to the S terminal of the relay.Always use a freshly charged battery when trying to start an engine.Once this has happened, any attempt to start the engine will be met with a NON-stop cranking of the starter
There are other reasons but your issue doesn't qualify
A LEO born in the year of the TIGER,so don't mess with ME
I speak in "Straight Talk" Deal with it.
Click for Red Deer, Alberta Forecast
  #16
Old 05-23-2012, 08:48 PM
thtniggey's Avatar
Put on a ground wire to the starter bolt and the truck fired right up!! the ignigtion still didnt work though still using the push button start for now! thanks for all the help!!
  #17
Old 05-24-2012, 02:57 PM
DNFXDLI's Avatar
Admin
You might want to look through this manual as well:
http://www.fordtruckfanatics.com/for...ad.php?t=29167
