  #11
Old 02-04-2018, 05:59 AM
jssjr1955 jssjr1955 is offline
jssjr1955 is on a distinguished road
Thumbs up
Thank you Bill. After looking at mine, that "turn to dust" is pretty much what is going on with mine. Not sure which one I need. There are a fuel gauge and temperature gauge - both work occasionally from whst I can tell. I am assuming the turn sugnals, high beam light, alternator light, oil light and brake light are there somewhere. Before I looked at it I could see one signal bulb working and the high beam bulb working. I think the odometer and speedometer worked at one time as well. I thought it just needed bulbs but I see it is more the crumbling cluster back part. Thanks again.
  #12
Old 02-04-2018, 11:03 AM
fatherdoug's Avatar
Dennis Carpenter lists two cluster backing plates.
E1PZ-10848-A Is for clusters with oil pressure and amp gauges
E1PZ-10848-B Is for clusters with warning lights for oil pressure and alternator.
'78 F-150 Lariat
Quote:
Quote:
  #13
Old 02-25-2018, 11:29 AM
Mine would be the one wqith the warning lights and not geuges. Thank you for the info.
  #14
Old 02-27-2018, 05:10 AM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond repute
I listed both these part numbers in post #10, listed their descriptions and said Carpenter had both.
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
