  #41
Old 07-06-2018, 12:30 PM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Started working on the tailgate. Removed the vertical reinforcement at both ends and cut out the rusty bottom edge.
- Russell
'77 F100 Flareside
  #42
Old 07-08-2018, 10:50 PM
fatherdoug's Avatar
Replaced battery, alternator, voltage regulator today. I also ordered and installed a headlight wiring harness with relays and fuses so I can use some 100W/80W bulbs in my Hella headlights.
'78 F-150 Lariat
  #43
Old 09-25-2018, 09:24 PM
fatherdoug's Avatar
Replaced valve cover gaskets on the 400 today. I was starting to smoke the exhaust pipe after 5 minutes of run time. It went better than I thought. The old gaskets(about 12 years old) were dry and brittle.
I tried something different this time - I put Permatex gasket sealant on the valve cover, then put the gasket on the cover and put the bolts through the holes from the inside to hold the gasket in place until the sealant got tacky. I then pulled the bolts and installed the cover, with only one minor adjustment to the gasket to fit the bolts through.
'78 F-150 Lariat
  #44
Old 11-08-2018, 04:17 PM
fatherdoug's Avatar
Drove it.
'78 F-150 Lariat
  #45
Old 11-08-2018, 07:22 PM
Jasperrc's Avatar
That's the best part!
- Russell
'77 F100 Flareside
  #46
Old 12-11-2018, 09:09 PM
Jasperrc's Avatar
Replaced the two primary instrument cluster illumination bulbs with LEDs. Wow what a difference!
- Russell
'77 F100 Flareside
  #47
Old 12-11-2018, 09:17 PM
fatherdoug's Avatar
night time pics?
'78 F-150 Lariat
  #48
Old 12-14-2018, 07:52 AM
Jasperrc's Avatar
My phone brightened up the pics a little but the difference with the new bulbs is night and day. The bulbs are Sylvania 194 White Zevo LEDs. And they work just fine with the dimmer.
- Russell
'77 F100 Flareside
  #49
Old 12-14-2018, 12:46 PM
fatherdoug's Avatar
Quite a difference! Thanks for posting. Has anybody figured a way to get an LED bulb into the auto transmission shift indicator? The ones I have found are too big in diameter to fit up into the hole.
'78 F-150 Lariat
  #50
Old 12-14-2018, 02:53 PM
406f150 406f150 is offline
406f150 is on a distinguished road
That's what I have trouble seeing in my truck too. Dash is tolerable, but those LED's sure make it better.
Got some new inside door panels, pads, and finger cups a while back to replace the busted ones from when someone took my truck for a joyride It's about to go into winter storage for the year.
