Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #21
Old 10-21-2018, 12:20 PM
Sparky83's Avatar
Sparky83 Sparky83 is offline
got the other side stained and sealed yesterday... today i worked on the side panels but had to pull the floor boards out from the bigger trailer (i been calling it my paint booth lol).. since i didnt have anywhere else to stick the floor panels before moving the wall boards i laid them on the smaller trailer for a bit.. got a glimps at how itll eventually look... nice to see the colors work well..
3 of the 4 side panels stained and sealed.. will flip them over tomorrow to do the other side... then ill have to work on the 4th panel..
also painted all the screws for the remaining brackets...
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #22
Old 10-21-2018, 01:26 PM
fatherdoug's Avatar
Looks nice.
'78 F-150 Lariat
  #23
Old 10-21-2018, 05:41 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Looking good
Click for weather forecast
________________
Randy
  #24
Old 10-21-2018, 06:23 PM
cbaker65's Avatar
cbaker65 cbaker65 is offline
Looks great ,are you going to use linseed oil for the wood!.....
CB
  #25
Old 10-21-2018, 08:37 PM
Sparky83's Avatar
nope... using Thompson Waterseal and stain... worked great for the seats i made for the go cart which sits outside all yr long...
Shawn
-John F. Kennedy
-Christopher Titus
  #26
Old 10-21-2018, 08:41 PM
Sparky83's Avatar
started staining and sealing the last board along with the blocks ill have to mount the outer latch piece too...
Shawn
-John F. Kennedy
-Christopher Titus
  #27
Old 10-24-2018, 05:52 PM
Sparky83's Avatar
Got the floor mounted to the trailer today along with 6 of the wall brackets. Then discovered 2 of my wall boards to make the box were way to long. So had to cut them and sand then re-stain/seal the ends i cut. Now i gotta wait for that to dry again.
Holes drilled for the floor bolts and flipped to mount some of the wall brackets.
Flipped right side up.
10 bolts to hold the floor just like a truck bed.
Shawn
-John F. Kennedy
-Christopher Titus
  #28
Old 10-24-2018, 09:55 PM
cbaker65's Avatar
Looks good Sparky!.....
CB
  #29
Old 10-25-2018, 12:19 PM
Sparky83's Avatar
thank you.... just need to finish it...
Shawn
-John F. Kennedy
-Christopher Titus
  #30
Old 10-25-2018, 05:48 PM
Sparky83's Avatar
Got the trailer done. Kinda. Have one little design issue to sort out then ill be fully done. Right now a bungie cord is fixing it. ill figure something out next time i go to town...
but for now heres how it looks... this was after i got the front and side walls on...
inside the box before i got the inside brackets on.. note the gap in the front of the box... wasnt real happy about that but when you got warped boards to work with you do what you can...
nice thing is the brackets pulled it down some...
rear gate attached...
and attached to my little gocart toy... pulled it well
Shawn
-John F. Kennedy
-Christopher Titus
