- 1
- 0
hi i have a 63 f100 an im putting a 460 big block with a c6....im going to leave the drum brakes but i wanted to put a dule master clinder but i dont know what would work...if you know please let me know
thanks
thanks
First year for dual master cylinders car & truck: 1967.dule master cylinder's for drum brakes were installed in 68-75 f100,
you will also need the porp valve (brake pressure differential valve)
It will replace the brake line Block mounted to the frame (where all the lines meet up under the truck), then you will need to have the correct lines for the front because i doubt the original lines will work for the front... i think the rear line will work but not 100% sure about that.
I would think about swaping in Disc brakes, with the extra weight of a 460 and if your going to drive it in traffic you may find them worth the money.
