Go Back   Ford Truck Fanatics > General > General Conversation
Old 11-13-2018, 07:48 PM
bradleyheathhays bradleyheathhays is offline
bradleyheathhays is on a distinguished road
cyl 7 misfire and coolant in the plug well
My '11 Crown vic with 270k miles suddenly started running rough mostly at the lower end of the gears. By the time you got into o/d the whole car shook. Scan tool gives me P0307 cyl 7 misfire, and P0316 misfire upon startup. So I pull the coil on 7 to find a pool of burnt smelling coolant about 2" deep. Siphoned and blew it out and removed the plug to find it's electrodes fouled with a thin coat of something shiny and black. Rubbed off without much effort. The plugs are about 4 weeks and 1500 miles old. Pulled cyl 6 coil right next to it and found a lot of white particles about half the size of rice stuck to the sides of the plug well walls. Seemed odd as I'd just blown out all the plug wells a month ago. Blew it out again and removed the plug to reveal electrodes that were coated slightly white. This plug had a ring of a black just south of the hex part. Looked like darkened sort of coagulated oil. Wiped off easily.
The car drives much better now after blowing the antifreeze out of the plug well but the miss is still there. So glad as this might buy me some time to get this figured out.
I'm not even sure how it's possible for coolant to get in a plug well. Any ideas, head gasket maybe? What's my next step in investigating?
Old 11-15-2018, 12:46 AM
I've gotten advice that this may be a leaky intake manifold or gasket. Is there a test I can perform that confirms it's my intake manifold that's leaking before I start taking parts off?
Old 11-16-2018, 12:38 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
The white particles is a sign of coolant being burned
Click for weather forecast
________________
Randy
  #4
Old 11-16-2018, 01:54 AM
Thanks for helping a stranger everybody. Found the leak at the front driver corner of the intake manifold. Really wish it wasn't so cold out now.
Any last advice on a cheap place to get a OEM intake manifold? Considering how much this car is driven I better stay away from after market.
  #5
Old 11-16-2018, 09:45 AM
dustybumpers's Avatar
Try rockauto.com
Charlie
  #6
Old 11-16-2018, 02:25 PM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
I second Rock Auto. Aftermarket isn't necessarily bad, just don't buy the cheapest one. I'm glad it was on the top end and your heads can stay on!
