Rear Hub Oil Slinger 07 F250
I had to perform surgery because the rear dust shield on pass side rotted out. I replaced the oil seal but re used the oil slinger. My oil slinger has a thin spring, rubber band like, that went around the tabs that were bent up and facing the bearing. When I installed the new seal the spring broke. I cannot find any picture online of a new one with a spring. I even called the local Ford Parts Department and the new ones don't come with one and the part diagram doesn't show one. Here is a short video I did to show the broken spring. Any insight is appreciated. Thank you for your time.
https://www.youtube.com/watch?v=BvgNaPlKiks
