Go Back   Ford Truck Fanatics > Engines > 6.0 Powerstroke
  #1
Old 08-20-2016, 08:46 PM
jebadiah04 jebadiah04 is offline
Rooster Snorkler
jebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud of
Took my turbo apart and it looks like a squirrel munched it up.
The unison ring is all corroded, thats why i pulled her apart, but what the heck is this all about? My first instinct was the bearings went and it was rubbing something, but there are absolutely no wear marks on anything, and the bearings are really tight. i cant get any slack on them whatsoever. my next guess it something got munched up in there. But with a stock air cleaner, i dont see a bird going through the turbo or anything.
heres the turbine wheel.
so do i need to swap this guy out, and which one do i get? it looks easy to swap, but ive never done it.
recommendations from those that know PLEASE.
1985 f-150 flareside
2008 f-150 crew cab
2005 f-350 Crew Cab Long Box diesel - for sale. Check out my classified post!
  #2
Old 08-20-2016, 08:58 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Holy crap Tater. Shawn (Sparky83) here has worked on those turbos before..once he sees this he will prolly have some good info.
Quote:
Quote:
Quote:
  #3
Old 08-20-2016, 11:02 PM
Rooster Snorkler
I'm wondering if my egr let a nugget through that hung up in a vein and did this. Either way. I guess I need a new one.
2008 f-150 crew cab
  #4
Old 08-20-2016, 11:09 PM
DNFXDLI's Avatar
Admin
I don't know...that should buff out.
  #5
Old 08-20-2016, 11:42 PM
Rooster Snorkler
Jb weld?
2008 f-150 crew cab
  #6
Old 08-20-2016, 11:43 PM
DNFXDLI's Avatar
Admin
Quote:
Originally Posted by jebadiah04 View Post
Jb weld?
Fawk yes....
  #7
Old 08-21-2016, 01:53 PM
Rooster Snorkler
does anyone know if that turbine wheel is replaceable in itself. Is it one piece with the shaft?
2008 f-150 crew cab
  #8
Old 08-21-2016, 02:46 PM
Lorddurock's Avatar
Lorddurock Lorddurock is offline
Lorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to behold
some aftermarket parts seem to available. as for the details and how to do it, i dont have these answers.
http://turbolabofamerica.com/6-0-pow...turbine-wheel/
http://www.xtremediesel.com/turboupgrades_4.aspx
im sure there are others.
the picture you posted the exhaust wheel?
"Everyone thinks of changing the world, but no one thinks of changing himself." tolstoy
"May you live your life as if the maxim of your actions were to become universal law" Immanual Kant
00 Vw jetta 2.0
77 f150 429
83 Buick century 4.3 diesel (lost to young fun)
-and many others
  #9
Old 08-21-2016, 02:59 PM
Lorddurock's Avatar
http://www.musclecardiy.com/performa...ent-wrong-fix/
found that. kinda looks like an over heat failure to me but the part has been cleaned so it hard to tell.
i have some good material on failure analysis in a book i use alot to find out why a part broke so i can do a complete repair. i will and figure out some way to get that info posted if you want. to help find out what happened.
00 Vw jetta 2.0
77 f150 429
-and many others
  #10
Old 08-21-2016, 03:03 PM
Rooster Snorkler
so, after thinking about this, since this turbine is on the hot side, that means whatever got in there came from the exhaust side of the engine. which means that either i had an injector tip come out or the dealership dropped a nugget when they did my injectors.
2008 f-150 crew cab
