Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > Tire Talk
  #11
Old 05-13-2014, 06:03 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
The difference in pressure specs could just be different load ratings.
Any 8 ply rating light truck tire runs at 65 psi for max load capacity.
10 ply tires run at a whopping 80psi for max capacity, as has been said.
Your other tires are probably a 6 ply or less, therefore requiring less pressure.
-Frank
Quote:
What's your view on sheep?
  #12
Old 05-13-2014, 06:09 PM
taxreliever's Avatar
taxreliever taxreliever is offline
taxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond repute
Ahhh...thanks for the clarity....didn't think there would be that much difference between the Interco Super Swampers and the Nitto Mud Grapplers, but I guess there is.
Ken
1977 F150 400 AUTO 4x4
1979 F250 400 AUTO 4X4
2006 F150 King Ranch
2007 Expedition EB
www.taxreliever.com
Quote:
Or, as the great Greek philosopher Testiclees once said: "Man who goes through turnstyle in airport is going to Bangkok."
  #13
Old 05-13-2014, 07:16 PM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
Hi Ken,
so you can see by the replies that you're good to run anywhere between 15-20psi Below the Max Load rating. You don't use your beautiful trucks to haul , do you...
Roy
yeeooow!
  #14
Old 05-14-2014, 06:29 AM
Quote:
Originally Posted by amkatt1 View Post
Hi Ken,
The only hauling this thing does is me and my boys!
So do I let some air out? Or just leave it alone at 65?
Ken
2007 Expedition EB
www.taxreliever.com
  #15
Old 05-14-2014, 08:31 AM
LEB Ben's Avatar
LEB Ben LEB Ben is offline
LEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond repute
Running max psi without a load will cause it to bounce like an over full basketball. PSI is a correlation to load index and sidewall/ply construction...ie bias/radial, nylon/Kevlar/steel, ply count, etc. Intent of a TSL is to be able to flex (even the radials), and 65psi doesn't promote that...they'll have a softer rubber compound as well that will allow more flex. I'd assume at 65lbs is a load range D tire and the Swampers are probably a C. Typically, I like my tires to be 10-15% less than max psi...but I suppose technically you need to get a weight at each corner and figure what percentage that is of the max load capacity of the tire, then multiply that percentage by the max psi. But no one does that, they either back off a certain percentage or fill that baby right up to the max psi.
'77 250 400 Boggers (show)__'96 350 CC 460 SSR's (work)__'79 Bronco 400 35's (play)
Quote:
Inspired by Ian
We live in a society that keeps finding answers to problems people never knew they had.
I bow my head to Jesus, stand for my family, love only one woman, and am always proud of what I have.
Standing by my gun and Bible since 1986.
Ben
  #16
Old 05-14-2014, 08:34 AM
Quote:
Ok, going to let some air out for sure now....thanks Ben....and thanks everyone else.....always learning with vehicles...love it!
Ken
2007 Expedition EB
www.taxreliever.com
