Go Back   Ford Truck Fanatics > Engines > Other Ford Engines
  #11
Old 05-18-2013, 06:59 PM
kiwi f150's Avatar
kiwi f150 kiwi f150 is offline
kiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond repute
Has your brother had a compression test done on it Andy? ...... it is probably getting down a bit with those 'kays on it and you might just find those cold starting issues showing up with winters arrival.
Whip the intake manifold hose off and shove a heat gun or the old chooks hairdryer in there for 5 min or so before trying to start it Andy - that'll give it some hot air and help with lower compression - if it starts then i'd look at fitting a block heater to it and plugging it in at night or driving it way , way , way up north and flogging it off..... it'd make a great donga for someone in the NT - especially as they only drive it for one tank of fuel lol.
Cheers Mark
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end."
  #12
Old 05-18-2013, 07:55 PM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond repute
Hahahaha that's racist!!!!
True mate, best do a compression test on it. He just rang said it wouldn start again today, I go have a look later
Andy
  #13
Old 10-18-2013, 12:48 AM
tjcustomranger's Avatar
tjcustomranger tjcustomranger is offline
tjcustomranger has a spectacular aura abouttjcustomranger has a spectacular aura about
our work trucks do it when it gets about 50 degrees out and they all have less than 100k on them. one little shot of starting fluid always worked good.
Tyler
1976 F-150 4WD 4 inch lift
35x15.5x15 super swamper tsl sx
360 with eddie performer and holley 4bbl
  #14
Old 10-18-2013, 03:20 AM
clutch's Avatar
clutch clutch is offline
clutch will become famous soon enoughclutch will become famous soon enough
hmm, fancy seeing this old post, seems to be similar to the trouble I'm having with my old IDI, have to plug 'er in below forty degrees farhenhiet, (replaced two bad plugs last fall), then after I changed the fuel filter in Feb, she's not wanting to start when she's all warmed up but has sat for a minute, finally took her to the mech, he said batteries, couldn't recreate the same circumstances I'm having... batteries didn't do the trick so I think he replaced a couple fuel lines that were seeping, I'll be picking her up later today... My theory all along was a fuel pump and or injector pump, someone said starter, and another says glow plug relay. Don't really want to keep throwing parts at her hoping something sticks, lol.
"...went back to the old Ford V-8. Can't beat that engine for getting there, oil-burner or no."
William Burroughs, Naked Lunch
Click for Truckee, California Forecast
