  #1
Old 01-29-2018, 02:57 PM
dna_32746 dna_32746 is offline
dna_32746 is on a distinguished road
Help with vacuum air intake/after throttle body
Hey there. I have an 88 F250 460 and I have a vacuum line from the back of the throttle body next to the firewall. I'm not sure where it is supposed to plug into. Can someone help?
Sent from my SM-G950U using Tapatalk
  #2
Old 01-30-2018, 07:26 AM
It's the #12 in the diagram that I can't determine where it connects.
  #3
Old 01-30-2018, 09:29 AM
fatherdoug's Avatar
I will see if I can get a look at my '89 460 today, if the weather cooperates. Thanks for the diagram. That helped.
'78 F-150 Lariat
Quote:
Quote:
  #4
Old 02-02-2018, 10:50 AM
fatherdoug's Avatar
Sorry for the late reply. I can't see behind the throttle body very well, but I believe that 1/4" tube goes to a box that is mounted on top of the A/C unit on the firewall.
I'm guessing the vacuum tube is to bump up the idle speed when the A/C is in service? Just a guess.
'78 F-150 Lariat
  #5
Old 02-04-2018, 04:12 PM
Thanks
  #6
Old 02-04-2018, 06:37 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
It actuates the heater door and other blend doors, the box is the reservoir.
My trucks:
