- Moderator
- #21
50K is kinda limited to be comfortable. Most people use way more that they think.
You need to buy special appliances normally LP to fit that budget for equipment alone.The load of a deep well pump, refrigeration, motors in washers and dryers will deplete a battery bank. With the limited charge capacity of solar it has to be backed up by either wind or preferably a hydro unit.
with a wind turbine you need to have a sustained wind speed of 13MPH IIRC and for the hydro unit you need a steady running river with a drop of a certain percentage. with these two options you have to run a LARGE guage cable to help reduce the voltage drop in the wires from the source to the batteries.
