Looks like I'm going to do this on our dealership car hauler. Who wants pitchers?
Jun 19, 2012 Moderator #1 blacksnaponModeratorStaff member9,461301 waynesville,mo. Looks like I'm going to do this on our dealership car hauler. Who wants pitchers?
Jun 21, 2012 Moderator #2 blacksnaponModeratorStaff member9,461301 waynesville,mo. Right rear body mount
Jun 21, 2012 Moderator #3 blacksnaponModeratorStaff member9,461301 waynesville,mo. Left rear body mount
Jun 21, 2012 Moderator #4 blacksnaponModeratorStaff member9,461301 waynesville,mo. third row body mount
Jun 21, 2012 Moderator #5 blacksnaponModeratorStaff member9,461301 waynesville,mo. third row mount (driver side)
Jun 21, 2012 Moderator #6 blacksnaponModeratorStaff member9,461301 waynesville,mo. pass side (behind the wheel)
Jun 21, 2012 Moderator #7 blacksnaponModeratorStaff member9,461301 waynesville,mo. Behind driver front tire
Jun 21, 2012 Moderator #8 blacksnaponModeratorStaff member9,461301 waynesville,mo. pass side under radiator
Jun 21, 2012 Moderator #9 blacksnaponModeratorStaff member9,461301 waynesville,mo. driver side under radiator
Jun 21, 2012 Moderator #10 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove shifter and bracket
Jun 21, 2012 Moderator #14 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove lower CAC hose
Jun 21, 2012 Moderator #15 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove clip and separate lower hose When you pull this one loose, you are going to get wet, No place to run, no place to hide! Last edited: Jan 1, 2013
Jun 21, 2012 Moderator #16 blacksnaponModeratorStaff member9,461301 waynesville,mo. disconnect maf, a/c, and filter minder
Jun 21, 2012 Moderator #17 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove air filter housing
Jun 21, 2012 Moderator #18 blacksnaponModeratorStaff member9,461301 waynesville,mo. recover freon (low side behind air filter)
Jun 21, 2012 #19 flareside_thunderFlorida Chapter member7,812246 You seem like you'd be a good mentor. I wish I could find a dealer willing to accept an apprentice for diesel tech. School is nice, but nothing beats hands-on. Keep those pictures coming.
Jun 22, 2012 Moderator #20 blacksnaponModeratorStaff member9,461301 waynesville,mo. right side pcm connector and connector below and left
